Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Windows, Doors, Locks & Vents > Windows & Screens
Old 04-07-2006, 08:35 AM   #1
JimGolden's Avatar
1977 31' Excella 500
Berkeley Springs , West Virginia
Condensation Drain Holes
Did 70's Airstreams with the dual pane windows have condensation holes drilled on an angle in the lower window frame from the factory?
I just noticed on my '77, every big dual pane window has had these holes drilled into the frames. Only the two front corner windows and the vista views do not have them.
I was thinking they did not come that way stock, but that some PO did it. Whoever did do it did a good job and managed to not hit any glass. It also keeps them from clouding up.
I'm going to have to knock the inner panes out on the vista views. The scotch tint has pulled loose and disentigrated and looks terrible...
- Jim
JimGolden is offline   Reply With Quote
Old 04-07-2006, 05:24 PM   #2
Jim.
Those windows did not come that way.
The Po drilled them for drain holes.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 04-08-2006, 09:50 AM   #3
JimGolden's Avatar
Thanks Andy!
- Jim
Old 04-16-2006, 10:33 PM   #4
7751
Torii's Avatar
1975 25' Tradewind
Huntington Beach , California
Hey Jim,
Any chance you have any pictures of these drain holes? If so, I'd love to see them. I had heard of this a while back and am thinking of doing that to my wing windows which are perpetually fogged.
Just not sure how to proceed. It would help to see a picture or two.
T-man
Torii is offline   Reply With Quote
Old 04-17-2006, 08:18 AM   #5
JimGolden's Avatar
T-Man, give me a day or two and I'll get some pics for you.
Looks like he drilled them on a 45 degree up angle, starting low on the outside below where the pane of glass is, then up on the angel to come into the void between the panes. I'm sure you want to be super careful, if you rub the edge of the pane too hard with the bit, it'll probably crack. I'll get some pics and put 'em on here as soon as I can.
- Jim
Old 04-22-2006, 11:07 AM   #6
JimGolden's Avatar
Finally got you some pics
T-Man,
Sorry so slow. Here are the pics. Some are better than others.
Basically, the PO drilled a hole of about 1/16" diameter or so on about a 45 degree angle in from the outer skin into the void between the panes. He did this on all windows but the vista views. You can see in the one pic how terrible my vista views look (I uploaded that image last but for some reason it got stuck int he middle...). I was going to bust out the inner panes on those, but saw a guy on here the other day talking about how he'd taken them completely apart, cleaned all the gunk out, and put a vent in. He was going to expound upon that proces and I've not checked back yet to see if he had. So that may be a better option. Anyway, I hope these help.
ID:	20699   Click image for larger version
ID:	20701   Click image for larger version
ID:	20704   Click image for larger version
- Jim
Old 04-22-2006, 03:45 PM   #7
mtbob's Avatar
1975 31' Sovereign
Billings , Montana
Insulating Glass Factoids
Those holes in the bottom of the window frames are not to drain the condensation from between the insulated glass, their purpose is to drain any accumulated water that leaks past the vinyl gasket, which wraps around the insulated glass, to the outside so the bottom of the glass does not sit in the collected moisture. This adds life to the insulated unit and I beg to differ from Andy, but they are factory applied. Check the insulated glass installation instructions from PPG Industries, the people who made the units originally.
mtbob
mtbob is offline   Reply With Quote
Old 04-23-2006, 07:53 PM   #8
JimGolden's Avatar
Interesting
Very interesting. Makes sense. I shall have to look into this further.
All I can say is that my big windows all have these holes and none of them seem to ever fog up. The vista views do not have the holes and they do fog up, in addition to looking horrible with the disintigrated scotch tint. It's on the list of things to fix.
Maybe the vista views collect moisture due to the outer gasket letting water get past, so that those double panes are sitting in a bath of moisture, and that causes them to fog up excessively?
- Jim
Old 04-23-2006, 11:33 PM   #9
7751
Torii's Avatar
1975 25' Tradewind
Hey Jim
Thanks for the pictures. My front wing windows suffer from constant moisture between the panes. It was suggested to me some time ago that I try this approach but as you point out it seems a bit risky to say the least. In the case of the wing windows I can't tell exactley where the glass begins behind the aluminum surround. I'd hate to break one as they are expensive to replace and clear ones are no longer available (smoked only)
here is the thread where I first heard of this drilling...
Thanks again!
-T
Old 04-24-2006, 08:13 AM   #10
JimGolden's Avatar
I believe I read that thread awhile back. Actually, one of my wing windows is solar gray and the other clear. I guess the PO must have broken one and replaced it with the newer one. Bummer for him! I actually never even noticed it...my dad did and pointed it out. He could always find the flaw in a Michaelangelo painting
- Jim
Old 04-24-2006, 08:20 AM   #11
mtbob's Avatar
1975 31' Sovereign
Billings , Montana
You've got it exactly right Jim. The other part of the problem is that over the years, the drying agent between the 2 pcs of glass becomes saturated with moisture and eventually begins to condense on the inside of the insulated unit. The technology used back then was not as efficient as today and insulating units still fail today for the same reasons even with new technology.
mtbob
Old 05-02-2006, 10:56 PM   #12
1986 34' Limited
South Lake Tahoe , California
window repair
Has anyone had success with taking the windows apart and replacing the desicant strip (which is available) after polishing off the baked on film? Has anyone asked Milgard to make a similar window for them; their windows are for life. Best, Ernie
Ernie2007 is offline   Reply With Quote
Old 05-04-2006, 09:58 PM   #13
Flower Mound , Texas
Smile Tint came loose
I have a 1974 that the tint appears to have come un-stuck to the windows. Mainly the Vista View windows. Does anyone know if you can get new replacement windows, or any ideas on how to fix the original windows?
Thanks!
booman80 is offline   Reply With Quote
Old 05-05-2006, 10:44 AM   #14
Thanks!
Replacement windows are available, but they are all single pane construction.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 05-05-2006, 10:58 AM   #15
Angel73's Avatar
1975 31' Sovereign
Woodlawn , Tennessee
Images: 65
Send a message via Yahoo to Angel73
Not sure but
Thanks!
But ours have like a silver ring around the vista windows on the inside.That my hubby remove and we just scraped the old tint.And now he waiting to put on new tint. Just a thought before have to spend money...lol
The Clark Family
Angel73 is offline   Reply With Quote
low drain points Raptorrider2001 1997 - 1999 Safari 21 10-07-2020 09:03 PM
Globetrotter 1963 - Kitchen Sink Drain Leak Under the Floor Uncle_Phil Plumbing - Systems & Fixtures 3 08-09-2002 06:59 PM
Air conditioner drain jcanavera Furnaces, Heaters, Fireplaces & Air Conditioning 3 07-10-2002 01:52 AM
Armstrong drain lines davidz71 Furnaces, Heaters, Fireplaces & Air Conditioning 4 07-03-2002 09:01 AM
Greywater drain pipe repair davidz71 Waste Systems, Tanks & Totes 4 06-04-2002 09:39 PM
