Old 08-20-2015, 09:19 AM   #1
60 Safari Land Yacht
1960 22' Safari
Burnet , Tx Hill Country
Clearview frame repair
My Clearview window frame has broken at the mittered 90. These frames appear to just have a blob of solder holding them together. Need advice on how to get it fixed. Thanks
Edventers is offline   Reply With Quote
Old 08-20-2015, 09:24 AM   #2
PA BAMBI II's Avatar
1964 17' Bambi II
Strasburg , Pennsylvania
I had a Hehr window frame fixed for my '64...aluminum welding.
Previous owner had used a steel angle bracket to fix it- ugly! The current repair is holding up well and blends right in.
"The difference between vintage and retro is that vintage is honestly old and cool. Retro tries to be but isn't."
PA BAMBI II is offline   Reply With Quote
Old 08-20-2015, 10:12 AM   #3
robwok's Avatar
1964 26' Overlander
Richmond , Virginia
Images: 35
Vintage trailer supply sells a welding kit for aluminum. uses these rods, but you have to get the metal you're bonding pretty hot. I've used it on small pieces, including one spot where the aluminum had been torn from my bumper trunk cover. was able to completely repair and polish it. I would expect you'd have to take the glass out to use it though. The other option might be JB weld for metal, but you'd have to be able to squeeze some mass in there. rough up the material, clean with acetone, then try it. I don't know what your windows look like though.
robwok is offline   Reply With Quote
Old 08-20-2015, 10:12 AM   #4
robwok's Avatar
1964 26' Overlander
Richmond , Virginia
Images: 35
Alumi-Pro Welding Kit
'59 Clearview Weatherstripping tonyp Exterior Restoration Forum 0 10-13-2012 10:24 AM
make a clearview window for '56 flying cloud? urbanfood Windows & Screens 7 03-23-2009 07:37 AM
shop repair of 1970s rear frame separation (non elephant ears repair) RV shop review simonhanbury Repairing/Replacing Floor &/or Frame 49 06-24-2008 09:16 AM
Frame Repair or New Frame muddy_hollow Brakes & Brake Controllers 14 09-26-2006 05:55 PM
