Old 10-17-2011, 12:24 PM   #1
1974 27' Overlander
Sammamish , Washington
Cleaning film off Vista Windows
I have removed my Vista Windows from a 74 Airstream and I am trying to clean off the film. Is there some solvent that just takes it off?
Kathie Neir is offline   Reply With Quote
Old 10-17-2011, 12:44 PM   #2
Alumaholic's Avatar
1966 24' Tradewind
Albuquerque , New Mexico
Images: 33
Please Clarify
Is the film on the inside, the outside, or between the panes?
There's a different approach depending on your answer.
A picture would help and you would get better advice.
Ken L
1966 Tradewind 24
2007Chevy Silverado 2500 HD Duramax/Allison
Four Corners Unit WBCCI #8654
Alumaholic is offline   Reply With Quote
Old 10-17-2011, 12:57 PM   #3
That film is mylar, and is on the inside of the outside pane of glass.
The only way it can be removed, is first take the window apart, and then 'VERY CAREFULLY", scrape the mylar off with a razor blade.
Old 10-17-2011, 01:08 PM   #4
1969 27' Overlander
Kathie, if the film is from old window tint (adhesive) you can use a solvent; Acetone, or Lacquer Thinner works fine. But, they are HIGHLY flammable and can cause flash fires if the fumes build up (ignition source not needed). The rags, too.
Clean the windows after taking them off the trailer, and use nitrile gloves and a mask if you don't want to get nauseous.
Also, a good "organic" cleaning solvent is PEANUT BUTTER. It melts through most sticky glues (price tags, etc.) But you have to then clean off the peanut butter with soapy water.
Hope that helps.
edglenn is offline   Reply With Quote
Old 10-17-2011, 01:29 PM   #5
Zeppelinium's Avatar
1975 31' Sovereign
1977 23' Safari
Palmer Lake , Colorado
Sounds like you have the vista views with a plastic inner pane and a glass outer pane--these come apart by removing the "C" clip in the interior of the trailer (you don't have to remove the window frame from the shell). In any event, all outer panes of vista views are glass and the film can easily be removed with a single-edge razor blade, once you have access to the inner side of the outer pane. You then have to wash the adhesive film off the glass--it's a very water soluble glue.
Zep
Vista View Window Questions CBWELL Windows & Screens 15 07-07-2012 08:36 PM
Can windows be made? lucymcdog Windows & Screens 22 07-29-2011 03:40 PM
Vista windows KenSanLan Windows & Screens 3 05-01-2011 06:32 AM
Vista View Windows.. this can't be right DanielB Windows & Screens 10 03-01-2011 09:22 PM
'73 Tradewind Windows Vista and Front Sides constructor Windows & Screens 8 01-28-2011 05:44 AM
