Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Windows, Doors, Locks & Vents > Windows & Screens
Old 02-13-2003, 02:14 AM   #1
pezz
Perry's Avatar
Profile:  1982 34' Limited
mire poix , midi pyrenees
changing screens
there is a easy way to change the mosquitos screens what is it ?
To put the little rubber in the groove and cut the mosquito screen afterwood ? Like any job it's always easier when you know.
PERRY
Perry is offline   Reply With Quote
Old 02-13-2003, 05:38 AM   #2
Profile:
Bugs out
I replaced several screens last year. No problem. Just remove the round rubber strip holding the screens. Reuse the same strip. There is a special tool that is handy. It is available at home stores. It is plastic and looks like a pizza cutter with a round wheel on each end. One wheel is used to place the strip in the groove and the other end is used to push it finally down into the groove. Rough cut the screen to size and insert the strip and use the tool for final installation. Last, with a sharp knife, trim the screen on the outside of the strip. Look at the old screen to see what the final results should look like.
Good Luck
Dan in Tennessee
Dbraw is offline   Reply With Quote
Old 02-13-2003, 07:57 AM   #3
Profile:  Boise , Idaho
Images: 21
Just to echo Dan, it's not hard at all once you get the hang of it. I started off replacing one window screen and ended up doing them all (including the door) because it was so easy. It's amazing how much dirt and grime is caked on those old screens. Like anything else, the first one is the hardest. Start with the flat ones until you master the procedure and then move to the curved. You can buy a roll of screen material at the home stores for about $20. The fiberglass screen material is easier to work then the metal and it comes in different shades. If you decide to replace the spline, take a sample with you to the store because it comes in several sizes.
Randy
Old 02-13-2003, 08:42 AM   #4
Road Ruler's Avatar
Profile:  1973 23' Safari
Burlington , South Western Ontario
Images: 45
Screen colour
I did one screen already in black fibreglass. Do any of you know if the dark colour will reduce light coming into the trailer? I think it would provide some privacy. Can you get as aluminum colour in the fibreglass?
Road Ruler is online now   Reply With Quote
Old 02-13-2003, 09:40 AM   #5
pezz
Perry's Avatar
screens
thanks dan
can't get that tool here in france . so might try the pizza cutter i tell you how i get on!
perry
Old 02-22-2003, 02:20 AM   #6
pezz
Perry's Avatar
pizza cutter
Hi all.
Well, my plastic pizza cutter worked.
I recommand it, if you can't find the proper tool, I say plastic so you can blunt it if needed.
I've got a lot to do as I have 4 Airstreams, and they all need doing, you know what it's like when your start ....
I found the same netting here in France, it was 7€ a meter(3foot) = 7 $.
I'm also doing all new curtains and carpets, I'll send photos when it's all done.
Thanks once again
PERRY
First European Airstream park http://www.airstreameurope.com
Toilet changing tips... drboyd Sinks, Showers & Toilets 2 07-18-2006 01:28 PM
Trailer-Aid for changing flats mtpalms Tires 9 06-09-2005 03:37 PM
Original Screens on 66 Caravel JMoy Windows & Screens 7 09-08-2003 04:08 PM
Changing Age of RVers jpurdy Our Community 21 07-24-2003 02:02 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
