Old 05-04-2011, 08:44 PM   #1
Becky B.'s Avatar
1964 17' Bambi II
Schererville , Indiana
Can't get window off 1964 Bambi II
I've removed the screw between the rain gutter & the window that holds the window from sliding, but I still can't move the window for glass repair. Any tricks I don't know about? I've read every thread I could find, but still don't know what I'm doing wrong.
Becky
1964 Bambi II
1988 Avion 32S
Becky B. is offline   Reply With Quote
Old 05-04-2011, 09:21 PM   #2
Chief Chili Cook
newroswell's Avatar
2010 30' Flying Cloud
Bakersfield , California
Becky, post a pix please.
newroswell is offline   Reply With Quote
Old 05-04-2011, 09:22 PM   #3
Beaker63's Avatar
1963 16' Bambi
Stevens Point , Wisconsin
Becky,
On our 63, there is a really tiny screw located at the center of the window. You have to open the window all the way, remove the screw, then it should slide out.
Tim
Beaker63 is offline   Reply With Quote
Old 05-04-2011, 10:03 PM   #4
Becky B.'s Avatar
1964 17' Bambi II
I removed a tiny screw that was on the outside in the center of the window. I had to bend up the rain rail to get at it (on the outside). Is there another one that I can't see? I don't have pictures right now. I'll have to get some tomorrow to post.
Becky
1964 Bambi II
1988 Avion 32S
Old 05-05-2011, 02:26 AM   #5
Petethefeet's Avatar
1964 30' Sovereign
1959 22' Flying Cloud
1957 26' Overlander
Raglan , New Zealand
Images: 14
Gently does it...
Without being able to see any pics....from my experience, if you lubricate the the top rail of the window and the grooved profile it fits into, liberally, with something like WD40, then open the window as it would normally, swinging the bottom out ,and with all hardware removed, only taking it as far up and out as it will go ( another set of hands will make this job infinitely easier), taking the weight of it, as it were, with the window open approximately 90 degrees to the body. Then, with a rubber mallet, gently tap the window sideways, preferably with a small block of wood nestled into the side of the window, near the top so it won't bounce or bend the frame, to blind the blows from the rubber mallet.You will find there will be a " sweet spot ", somewhere if you raise or lower the window frame as you tap sideways, and it should slide out. There may be a little resistance but take your time and do not force things, you should be right. There should also be a tiny nylon/teflon block that is housed in a small slot in the top of the window rail, that the small centering screw ( which it sounds like you have already removed ), is screwed into. Watch out for it as you draw the window out, as it is just sitting there. Hope this makes sense and is not too long winded. Good luck.
Pete
Petethefeet is offline   Reply With Quote
Old 05-05-2011, 05:59 AM   #6
Becky B.'s Avatar
1964 17' Bambi II
I just ran outside at 7:00 a.m. & tried Pete's suggestion. Block of wood, deadblow hammer & "gently tap" the side. It started moving & kept going right out. I sprayed with dry lube last evening. I kept the little piece of plastic that's in the center of the frame for re-install. I was just afraid to break anything, so the advise was welcomed! Thanks, all!
Becky
1964 Bambi II
1988 Avion 32S
AS280 - Front (driver) sliding window latch dalefox Classic Motorhomes 14 09-13-2018 08:05 PM
Rear window leak fixed! Really? I think so. 1964 GlobeTrottin 1960 - 1964 Globetrotter 0 04-30-2011 05:42 AM
1964 Bambi II Airstream eBay Watch Airstreams on eBay 0 04-26-2011 12:40 PM
Replace missing front window with jalousie? Cruisette Windows & Screens 6 03-31-2011 04:23 PM
Love my T@B, but looking for a vintage Bambi BambiWannabe Member Introductions 3 03-13-2011 09:17 PM
