Old 05-18-2013, 02:09 PM   #1
1973 Argosy 26
tallahassee , Florida
can't get window back on
I removed a window to replace weather striping and to tint it but now iI can`t get it back on. Is there a trick to getting the window to adhere to the lip?
sharley0716 is offline   Reply With Quote
Old 05-18-2013, 03:46 PM   #2
Vince & Virginia
Towster's Avatar
1969 21' Globetrotter
Riverside , California
There's some discussion of it in this thread.
http://www.airforums.com/forums/f164...ml#post1248221
If the hinge is still reasonably straight, the key is to lift the window somewhere approaching almost vertical to get it to pop into place. Just don't lower it until you are sure it is in all the way.
Good luck.
Virginia (SoCal Silver Sister)
"The Towster" 1969 Globetrotter 21' (Silver)
"The Yeti" 2001 Chevy Silverado 2500HD 8.1 Allison Crew Cab (White)
"The Boat" Old Town Canoe Discovery 174 (Green)
Towster is offline   Reply With Quote
Old 05-18-2013, 03:47 PM   #3
1977 Argosy 24
Milltown , Wisconsin
The window must be centered in the opening, if not there are stops on each end of the channel that it fits in, and the lip will hit them. Lift the bottom of the window higher then the top track that it fits in, and push up on the lip of the window that goes into the channel. Then slowly lower the bottom of the window while pushing up on the top of the window to engage the channel. Hope this makes sense. Brian
ventport is offline   Reply With Quote
Old 05-18-2013, 04:50 PM   #4
Vince & Virginia
Towster's Avatar
If your trailer has the same hinge on the lower hatches, try practicing on those till you get the hang of how it works.
Old 05-18-2013, 07:31 PM   #5
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
The hinge on the window must be centered. A$'s way is to put rivets into the drip edge above the window opening.
Those rivets penetrate the part of the hinge that is above the window. You must make sure you are in between those rivets. Or the window will not go in.
DO NOT FORCE THE WINDOW DOWN. You will ruin the hinge. It should drop down freely when positioned correctly.
Old 05-19-2013, 07:08 AM   #6
1973 Argosy 26
Thanks for the great info. We did have it between the two bolts but were more at a 45 degree angle. Ill try the straight verticle today. We did attempt this on our lunch hour with our 5 month old asleep in the car. Not such a great idea. My husbsnd and I are going to need couple's therapy once we get these things in
Old 05-19-2013, 08:13 AM   #7
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
A good platform a foot or so hign makes an easier install. Also front and rear double panes are hefty. Having a second pair of hands sure helps.
Old 05-20-2013, 06:34 AM   #8
1973 Argosy 26
Thanks to all for the help. We got them on in about 30 minutes this time! Now, just 5 more to go.
