Old 02-14-2016, 01:53 PM   #1
Gordon
2014 30' International
Scarborough , Ontario
Can plexiglass windows be repaired?
The front centre plexiglass window in our 2014 International has attracted a flying stone and has a pretty star of cracks as a result.
Can this damage be repaired in the same way as chips in the glass windshield of a TV, where a compound is squeezed into the cracks and set by UV light?
Would appreciate any guidance please and thanks.
Gordon Moore
WBCCI 4704
Gmoore is offline   Reply With Quote
Old 02-14-2016, 02:06 PM   #2
HowieE's Avatar
Princeton , New Jersey
Images: 12
Auto glass has 2 layers and thus some structural support for the outer layer but the inner layer. Your plastic window in single layered and the common means of repairing Plexiglas is a melting bond. that wold likely leave distortion in the window.
I have replaced one of the curved Plexiglas windows on my trailer by just buying the material at a plastic supply house.
2004 Excursion 4x4
Old 02-14-2016, 03:35 PM   #3
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
IMHO If you are going to replace the damaged window. I would use LEXAN or an equivalent polycarbonate instead of plexiglass.
Where can I get my windows repaired ? bcdog Windows & Screens 2 04-18-2014 12:21 PM
Dometic RM 75 dead - can't be repaired Alumin8 Refrigerators 24 09-03-2006 12:56 PM
Can this be repaired for $5K? yukionna Our Community 41 02-11-2005 09:15 PM
Freshwater tank leaking - can it be repaired? drboyd Fresh Water Systems 3 09-13-2003 10:03 PM
Can my toilet be repaired? drboyd Sinks, Showers & Toilets 4 09-08-2003 09:17 PM
