Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Windows, Doors, Locks & Vents > Windows & Screens
Old 02-26-2010, 10:03 AM   #1
adwriter73's Avatar
2005 16' International CCD
can i cut the window hinge?
I pulled all the windows out to replace the gaskets. The track of one of the window frames has a slight kink in it. Not sure why, but it is now impossible to get the window hinge to clip back in -- me and my dad tried for an hour. The "kink" is on the very corner, meaning, if I cut off about 1/2 an in hinge so that there's no part of the hinge in that area that needs to "hook" on, then it should work. The rest of the hinge clips in fine. Obviously, I'm nervous about doing this because I can't replace that hinge. Advice? See the pic below for a a visual of what I want to cut.
adwriter73 is offline   Reply With Quote
Old 02-26-2010, 10:18 AM   #2
Kevin245's Avatar
I suppose you could cut it...but it seems that if it came off then it should go back on unless it was damaged during the removal or cleaning process. Do you recall how easily it came off?
If it were mine I'd avoid cutting it. I can't see the damage very well in the photograph. Perhaps you could get another shot or two of the area.
Kevin
William C. Swinney
Old 02-26-2010, 10:42 AM   #3
CanoeStream's Avatar
St. Cloud , Minnesota
I'm not sure I see a specific problem from your picture. As Kevin asked -- any enlargements or perspectives to show it better? It's difficult to guess if simply cutting off part of the rail will solve this.
I took off the rear window on my Argosy to replace gaskets and struggled mightily to get it back on. This probably was due to shell distortion from rear end separation in my case.
5 meter Langford Nahanni
Old 02-26-2010, 10:49 AM   #4
Minno's Avatar
1972 31' Sovereign
Lexington , Minnesota
I had trouble getting all of the windows back on our '72 Sovereign after taking them off to clean and install new gaskets. Some of them you need to hold in the open position as far as they would go to slide back into the hinge, while others worked at about a 45 degree angle above horizontal. If you cut part of the hinge off, then the window will be able to slide forward and backward in the hinge. There are stops in the frame that you need to center the hinge in between. Then, for most of our windows, holding them at the 45 degree angle I mentioned, plus pushing up on the center and then the outside edges of the hinge popped them back into place. It was a two person operation, with one of us holding the window, and the other one guiding and then pushing the hinge upwards back into place.
Chris
Old 02-26-2010, 11:15 AM   #5
adwriter73's Avatar
Sorry, I wasn't clear. The picture doesn't show the problem. It just shows what I want to cut. The problem is the track/frame on the exterior of the trailer. I can't get a shot of it. In fact, you can't see it. But, if you run your finger along the inside of the the track, you can feel it bend in slightly right at the stop. I think it is bent in just enough that the hinge won't "grab" on.
Old 02-26-2010, 11:18 AM   #6
The aluminum is soft enough to be filed or sanded if it's only a very small kink in the end of the track. I wouldn't cut it as it probably contributes to keeping the water running away from your interior.
Rich the Viking
VIKING is offline   Reply With Quote
Old 02-26-2010, 12:49 PM   #7
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
If there is a kink I would think it could be bent straight, maybe with a needlenose.
Are you sure you are lifting the window high enough to get the hinge parts to mate? You need to go pretty high past 90 degrees.
Old 02-26-2010, 01:43 PM   #8
ts8501's Avatar
2022 25' International
Savage , Minnesota
My Hehr Mark 12's go in and out at a 90 degree angle. Covered on posts 23-26 here.
"I've got aluminum fever, and the only prescription, is more AIRSTREAM!!!"
'64 Safari Resoration Blog ("May"):
https://ts8501.blogspot.com/
TAC MN-6
WBCCI/VAC 11736
AIR 25979
ts8501 is offline   Reply With Quote
Window Hinge gwest@ridgec Windows & Screens 0 09-10-2006 11:33 AM
window hinge leak? art Windows & Screens 0 09-05-2006 06:01 PM
Window Hinge - 1968 Ambassador 68LANDYACHT 1966 - 1969 Ambassador 3 09-16-2005 05:02 PM
'68 Window Hinge Over59 Windows & Screens 17 09-17-2004 08:44 AM
Sovereign 1992: Want to cut a window in the roof. Has anyone experience? Hans Roof 20 01-18-2003 05:23 PM
