Old 07-21-2015, 09:38 AM   #1
Cardinal283's Avatar
Dallas , Texas
Butyl tape
I'm sure this has been discussed. But I'm traveling and searching using a phone on this forum is a nightmare.
Why do we use butyl tape on the windows instead of using a sealant? With a marine repair background, I get why on boats. They need to be popped out and resealed from time to time. But on an AS the window frames are riveted in. Not easy to remove and reseal. What are everyone's thoughts/understanding on this subject?
Cardinal283 is offline   Reply With Quote
Old 07-21-2015, 09:59 AM   #2
Mission , Texas
Never heard of it, but I'm fairly new to this.
I did perform the dreaded wing window replacement on my 75.
There were no signs of leakage. The inside was gooped over with a rubbery never completely dried yellowish white compound, where the window frame and skin met was likely the tape mentioned. Removing the original bucked rivets and window revealed that bucking (beating) rivets can lead to a formerly flat surface having waves.
Re-assembly - after smoothing out the waves, gooped up the skin and window frame with a caulk line of Vulkem's replacement to the point it oozed out of the rivet holes, Olympic rivets, wipe the outside pretty with a paint thinner rag, goop up the inside as found, allow a couple of days set time - then leak test with a hose. No leaks.
My suspicion is that many seam leak problems are related to bucking, no goopy gasketing with a caulk line on both surfaces, and gooping the inside after riveting.
But I've never done a complete rebuild, followed by another complete rebuild 40 years later to see if the change in technique was any benefit or not. :P
Tape is likely used in original assembly as it is easier.
nrgtrakr is offline   Reply With Quote
Old 07-22-2015, 03:10 PM   #3
Dallas , Texas
I don't have the dreaded wing windows on mine so I can't say much about that. But the part where you used vulkem on the window frame to seal it to the skin is where the butyl tape goes. Butyl tape never hardens unlike sealants. I think I may have just answered my own question as to why we use butyl instead of sealant.
Old 07-22-2015, 03:43 PM   #4
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
I used butyl tape when I put vent caps on my Bambi II. It was neat and clean as opposed to how some sealants can be. It takes to irregular shapes and makes for a good water tight seal.
MICHAEL
Old 07-22-2015, 04:49 PM   #5
Gregsch's Avatar
1979 24' Airstream Excella 24
Tipp City , Ohio
If you install a window with Vulkem or Trempro 635 it will be almost impossible to get it apart if you ever need to. The butyl is designed to stay flexible indefinitely. It will move with parts as they expand and contract due to temp changes, and due to stress and vibration from driving down the road.
Gregsch is offline   Reply With Quote
Use of Butyl Putty tape cheetah1 General Repair Forum 19 06-10-2015 12:23 PM
Correct method for using Butyl putty tape on window frames dcole Windows & Screens 2 03-15-2015 11:25 PM
butyl putty tape on the roof bacevedo Leaks - Weatherstrips, Gaskets, Caulks & Sealants 5 02-22-2009 06:09 PM
Source for pre-shimmed butyl tape pnb77 Leaks - Weatherstrips, Gaskets, Caulks & Sealants 1 04-09-2008 10:48 AM
Seeking advice on replacing butyl tape sealant on ridged aluminum SOB SilvrSausage Vintage Kin 0 09-23-2007 12:03 AM
