Old 12-06-2015, 12:38 PM   #1
1957 26' Overlander
Santa Monica , California
Building a Herhr window
Someone pulled out the rear window on my newly purchased 1957 Airstream Overlander,and put in a house AC unit. The original window was not included when I purchased the Airstream. So now I have to fabricate a new window. I am going to try to make an exact copy of the original style Herhr window. I have purchased a piece of 2024 t3 aluminum and made up a cardboard mock up of the bends that I have to make to fabricate the window. It is my understanding that the rear window has some sort of escape hatch or something on the rear window. I have no idea what that looks like. Does anyone have any tips or ideas for fabricating this window? Or pictures of the rear escape hatch setup? Thanks
Dnsn2007 is offline   Reply With Quote
Old 12-06-2015, 03:21 PM   #2
65CV's Avatar
Western , Massachusetts
'57? Sweet!
The Photo Archives at VintageAirstream.Com may help. There are several sets of pictures to choose from.
65CV is offline   Reply With Quote
Old 12-06-2015, 03:52 PM   #3
Central , Mississippi
I've built several of these windows, the T3 temper is going to be a bear to get the outer fold without cracking.
I used 3003, it polishes up pretty good, the slight color difference isn't noticeable since its a standalone piece and just a narrow ring around the glass.
Vintage trailer supply has the extrusions that go vertical up the window and the cranks slide in. The steel pieces that hold the openers isn't too bad to replicate except making the slot. A hand grinder with a cut off wheel will work if you don't have a mill.
The bend sequence is pretty critical so you don't work yourself into a corner.
A miss step with a polisher will have you starting over...
Name:	ImageUploadedByAirstream Forums1449442301.808290.jpg
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie -
A honkin' long 34' named AlumaTherapy http://www.airforums.com/forums/f205...num-54749.html
and a 26' '63 Overlander, Dolly http://www.airforums.com/forums/f109...ome-71609.html
Old 12-06-2015, 03:56 PM   #4
They do look nice when polished. Click image for larger version
Name:	ImageUploadedByAirstream Forums1449442589.040613.jpg
Old 12-06-2015, 06:23 PM   #5
1957 26' Overlander
The 3003 aluminum is a great tip. Thanks!
Sent from my iPad using
building custom bathroom / interior pinkflamingoes Cabinets, Counter Tops & Furnishings 33 11-26-2006 05:27 PM
I'm thinking of building a dinette Stefrobrts Cabinets, Counter Tops & Furnishings 29 02-11-2006 08:45 AM
Modern building materials in vintage restorations bredlo General Interior Topics 18 12-05-2003 07:16 PM
Building in a Computer area in closet JLD General Interior Topics 5 12-05-2003 04:03 PM
building bunk beds munimula General Interior Topics 13 10-14-2003 05:59 AM
