Old 07-06-2014, 07:29 AM   #29
Becky B.'s Avatar
1964 17' Bambi II
Schererville , Indiana
I don't need lower guards because I have an Avion. They're anodized & the aluminum doesn't seem to dent as easily as the Airstreams do. Also, I'm trying to be a bit less anal with this trailer than I am with my Bambi II. Unlike Airstreams, the money you put into an Avion doesn't really recoup when/if you sell it (generally). The windows are unobtainium if they crack...I can live with a rock dent in the aluminum if it happens. I had lower rock guards on my '86 Airstream and really liked them!
Becky
1964 Bambi II
1988 Avion 32S
Becky B. is offline   Reply With Quote
Old 08-04-2014, 05:45 PM   #30
Becky B.'s Avatar
1964 17' Bambi II
I changed my mind in what to use to secure the rock guard down. The kind I was going to use looked huge, so I opted for some stainless rope guides that I zip tie together before travel. I used the trailer for 2 weeks & the rock guard worked like a charm.Click image for larger version
Name:	ImageUploadedByAirstream Forums1407192290.472803.jpg
ID:	218279Click image for larger version
Name:	ImageUploadedByAirstream Forums1407192300.425301.jpg
ID:	218280Click image for larger version
Name:	ImageUploadedByAirstream Forums1407192310.890048.jpg
ID:	218281Click image for larger version
Name:	ImageUploadedByAirstream Forums1407192322.256769.jpg
Becky
1964 Bambi II
1988 Avion 32S
Old 02-16-2015, 09:12 PM   #31
Becky B.'s Avatar
1964 17' Bambi II
Quick update....I took the Avion about 2,000 miles & the rock guard held up just fine. No problemos :-)
Becky
1964 Bambi II
1988 Avion 32S
Old 02-16-2015, 10:12 PM   #32
Glenritas's Avatar
1969 25' Tradewind
Shasta Lake , California
This is what the factory used ... mini rubber hold downs .
I believe Vintage Trailer Supply has them.
ID:	232579   Click image for larger version
Name:	TW Rt Frt i.jpg
Glen & Jane 1969 all electric Airstream 25' TradeWind
2014 Toyota Tundra
1998 Chevy Tahoe
2001 Casita 13' Patriot Deluxe
My Build Thread https://www.airforums.com/forums/f11...ml#post1997059
Glenritas is online now   Reply With Quote
Old 02-17-2015, 06:14 PM   #33
Regular Guy
NavyCorpsman's Avatar
1978 31' Sovereign
Hot Springs , Arkansas
Very nice! I just finished cutting .063ga sheet Al to size, bent the vertical radius and started the polishing process for mine. Its not bulletproof like yours, but will keep the rocks away from my window.
Thank you for the pics too.
Clayton
NavyCorpsman is offline   Reply With Quote
Old 03-17-2015, 01:56 AM   #34
lifeincolor's Avatar
Salem , Oregon
Guess who just bought a 1984 Avion 30R with a boring black not see through at all rock guard? Me. I can't believe I stumbled upon this I am just in love with your rock guard!! We had a huge windstorm here and I was bummed about having to have the rock guard closed because the trailer got so dark (since it was overcast anyway). I'm adding this to my must do list! Simply amazing!!! Thank you for all the detailed photos!
lifeincolor is offline   Reply With Quote
Old 07-31-2015, 01:59 PM   #35
Becky B.'s Avatar
1964 17' Bambi II
Mine is still hanging in there after a year (my daughter's is too). I don't even have to open it because I can see through it. Hope you have had time to make yours!
Becky
1964 Bambi II
1988 Avion 32S
Old 08-01-2015, 09:14 PM   #36
rodsterinfl's Avatar
2006 25' Safari
Fort Myers , Florida
Images: 8
I think it's plexiglass in the original ones. They're not drilled anywhere. I think Lexan could slide in just fine
Good to know. A rock cracked mine on the summer trip last month. I would like smoked lean. Do you know the thickness of the plastic Airstream uses in their rock guard. i would like to "slide my warped, cracked piece out of the frame and replace it with this stuff. I just have a single piece on the front with no bends, only rounded corners.
WBCCI 8653/AIR 60240
2017 Ford F-150 3.5 Ecobeast Gen 2 3.55 Platinum
Old 10-24-2016, 09:57 PM   #37
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
Build your own rock guard...you can do it!
Sorry I missed this before. Late on the compliments (as with all your work), but genuinely so.
I'd like to do something like this on the giant rear window of my SS (same size as front), but it was in again researching interior storm windows that I found this thread. And it's applicable!
Thx
1990 35' Silver Streak
2004 555 Cummins
Hensley Arrow. 9-cpm solo, 15-cpm towing
Old 11-28-2017, 12:21 AM   #38
1978 31' Sovereign
Aumsville , Oregon
I think I'll be borrowing this idea. Does anyone think I could get a similar radius on the aluminum angle by using a shrinker instead of cutting so many notches? I've been thinking about getting a shrinker/stretcher for our renovation, but haven't used one before.
pvfjr is offline   Reply With Quote
Old 11-28-2017, 12:34 AM   #39
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
Yeah, I think you can, just make sure you get a set of jaws made for aluminum.
I have a pair I use for steel, I never bought the aluminum jaws, I know I could make that radius in steel.
Old 11-28-2017, 08:38 AM   #40
Dingo Girl's Avatar
1967 17' Caravel
Cadillac , Michigan
Shrinker stretcher is very easy to use.
Dingo Girl is offline   Reply With Quote
Old 11-28-2017, 02:10 PM   #41
J. Morgan's Avatar
1972 31' Sovereign
Benton , Arkansas
Images: 11
I used a shrinker and a stretcher to recreate the C-channel that goes around the back of the trailer. They are great tools to have. Click image for larger version
Old 11-29-2017, 12:55 AM   #42
1978 31' Sovereign
Aumsville , Oregon
Originally Posted by J. Morgan View Post
I used a shrinker and a stretcher to recreate the C-channel that goes around the back of the trailer. They are great tools to have. Attachment 299930
That is one tool I'm fairly ignorant about. How did you do a piece of c-channel in that plane? I would think you'd only be able to put the side walls of the c into the device. I guess I'd better hop on youtube.
What's the difference with steel vs aluminum jaws? Will the jaws intended for steel mar the aluminum? Or will they just not grip it properly?
Cleaning your Rock Guard Rollster Cleaning, Stripping & Polishing 43 06-11-2017 09:34 PM
Own your own scale? Ag&Au Jacks, Stabilizers, Lifting and Leveling 8 01-26-2014 03:52 PM
Build your own Control Panel DanielB 1973-1974 Excella 500 0 03-21-2011 06:59 PM
