07-21-2004, 08:22 PM
Bubbling Windows
We are new owners of a 77 Excella 500. There are a couple of windows that are bubbling. I, at first thought that it was an interior sheeting tint and I could just strip and reapply. However, it appears the tint is inside the glass, right? Does this mean the window must be replaced and if so can a standard glass company do it?
07-21-2004, 09:04 PM
2002 27' Safari
Carmel-by-the-Sea
You have the Thermapane (pain)dual pane windows that tend to delaminate. Andy at Inlandrv.com can get replacements,but I believe there single pane and not cheap.Or you can check into Colaw's RV salvage,that has been mentioned on many previous posts.I haven't heard of any standard glass companies,that can create the curvature needed.Good luck in your search,we have a few that are doing the same,we rotated them into the bedroom area.Jeff
07-21-2004, 09:15 PM
1979 30' Argosy
Havelock
, where we park it
Inside pane
Hello.. The inside pane can be removed ....... do a search.. no need to buy new.. single pane will work great.. Annie and Marvin
Marvin & Annie
Niki (fur baby)
1979 Argosy 30 (Costalotta)
WBCCI 10103
"Happiness is a warm Puppy" Charles Schulz
07-21-2004, 09:33 PM
2002 27' Safari
Carmel-by-the-Sea
I've been doing a search for removing the inner pane of these windows. thus far,I have only have found or knew of removing the inner pane from the lower sill windows and the upper vistaviews,but nothing regarding the curved framed opening windows.Jeff
07-22-2004, 05:09 PM
Thank you.
Thank you Happy. I went out and took a looksee. I then noticed that our kitchen window inside pane had been removed. I thought they had just bought a new glass without a tint until further investigation. Now I will have to pursued my better half that the single pane looks better than all the bubbles. He won't be easy to sway. He doesn't want to give up the tint or the double pane. But I guess I can reapply an auto tint after I remove the inner pane?
03-20-2005, 04:55 AM
I have a '77 Overlander with a bubbling window in the door. I'm enclosing a picture of it. Is this the same problem you're talking about? Will removing the inner pane solve my problem too?
I ask because I wonder why the panes are double in the first place? Is it for insulation, or strength? Will the window be more subject to cracks and breakage (on the road) if the inner pane is removed?
'77 Overlander: 'Betty'
03-20-2005, 05:09 AM
1974 27' Overlander
1954 26' Romany Cruiser
1960 26' Overlander
Rockingham County
, New Hampshire
On my '75 Tradewind the UV protective coating peeled off. It was a pretty easy repair. Does your look like these?
http://www.balrgn.com/Airstream/DSC02242.jpg
http://www.balrgn.com/Airstream/DSC02251.jpg
The inner window came out pretty easy, there is an aluminum retaing ring hold it in.
'74 Overlander (T-O-Bee)
'46 Spartan Manor (Rosie)
'54 Cruiser (Bogart)
'60 Overlander (Hoagy)
WBCCI 1754 - AIR # 6281
www.balrgn.com
03-20-2005, 06:41 AM
Old Paint, rolling again.
1973 Argosy 20
Lorain County
, Ohio
double pains
I was confused by this old thread a couple of weeks back when I was looking for info on double pane windows. I bought a used side window that's tinted between the panes and though the tint is okay a couple of the little air pins between the panes have fallen out. I looked real hard at getting the inside pane out and there is no way. The 2 panes are a sealed package that is wrapped in the aluminum frame channel. Perhaps vista views can come apart but aparently not standard top hinged windows.
Steve
Have you never questioned those who travel? Have you paid no regard to their accounts- Job 21:29
