Old 08-20-2007, 08:58 PM   #1
Coulter's
1974 31' Excella 500
Houston , Texas
Question Bubbles in my windows
1974 Excella 500 ALL of my side windows have a clear bubble INSIDE between the panes. My auto glass company says they don't know how to fix it but it would involve disassembly and a lot of man hours. Any Ideas on this problem? Is the window glass available anywhere. Momma Don't Like It!
Thanks!
Greg
Greg
1974 Excella 500
"Land of The Free, Because of The Brave"
Greg Coulter is offline   Reply With Quote
Old 08-20-2007, 11:46 PM   #2
1992 34' Limited
Falls Church , Virginia
Special FEATURE!!!!!!
Greg -
Any way that you can pull off having any kind of "Special Feature" that NO OTHER AS HAS!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
This is the feature that is searched for LONG AND WIDE by collector AS Enthusiasts....... bubbles in the side glass......
Make a positive out of a negative.
Just a thought.
Axel
SilverToy
SilverToy is offline   Reply With Quote
Old 08-21-2007, 06:12 AM   #3
Zeppelinium's Avatar
1975 31' Sovereign
1977 23' Safari
Palmer Lake , Colorado
Greg,
The bubbles are in the solar film that's attached on the inner surface of the outside window. Many members have broken the inside pane and removed it entirely, then cleaned the film off the other pane and just lived with a single pane solution (didn't I type this same sentence yesterday?).
Some of us are confident we can figure out how to get the window frame apart and solve this problem, but no one has posted photos yet.
Zep
Old 08-21-2007, 06:19 AM   #4
Got gandkids?
Jim & Susan's Avatar
'Possum Holler , Georgia
Somebody did figure this out recently. Now, if I can just remember who it was. I think I bookmarked it someplace.
JIm
www.nesa.org
Air No. 6427
Old 08-21-2007, 06:29 AM   #5
davidz71's Avatar
1986 25' Sovereign
Southern Middle , Tennessee
Originally Posted by SilverToy
Greg -
Just a thought.
Axel
SilverToy
If he could only figure a way to get live fish in between the window panes he would have it made.
Craig
AIR #0078
3.73 rear end
Mag-Hytec rear diff cover
Amsoil synthetics all around
Old 08-21-2007, 07:01 AM   #6
Got gandkids?
http://www.airforums.com/forums/f454...eal-31450.html
This is the thread I was thinking of. Maybe it will help some.
www.nesa.org
Air No. 6427
Old 09-01-2007, 10:16 PM   #7
Coulter's
Houston , Texas
Smile Windows
Jim;
Thanks for the thread. I have disassembled one window, and aside from the fear factor it went smooth. About 10 minutes and it was apart. I am going to clean and have my glass guy re puddy them and I will reassemble the frames. Still looking for the weatherstrip for the frames.
If I can figure out how to post the photos with notes I will do a step by step.
Thanks!
Greg
Greg
1974 Excella 500
Old 09-01-2007, 11:19 PM   #8
Originally Posted by Greg Coulter
Jim;
Thanks!
Greg
There are two different types of gasket for the windows.
One is the original double flared gasket, and the other, we feel is far superior, is a "D" shaped gasket.
The "D" shaped gasket is hollow and makes a much tighter seal than the original.
Old 09-02-2007, 06:18 AM   #9
47WeeWind's Avatar
1948 16' Wee Wind
1953 21' Flying Cloud
Denver , Colorado
Images: 20
1974 Special Editions . . .
Greg - Any way that you can pull off having any kind of "Special Feature" that NO OTHER AS HAS!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! This is the feature that is searched for LONG AND WIDE by collector AS Enthusiasts....... bubbles in the side glass...... Make a positive out of a negative. Just a thought, Axel SilverToy
Depending on the size of the bubbles, it's either the coveted Don Ho Limited Edition or that year's offering aimed at the WBCCI Leadership, the Lawrence Welk Champagne Edition.
Fred Coldwell, WBCCI #1510, AIR #2675
Denver, Colorado - WBCCI Unit 24
Airstream Life "Old Aluminum"
Airstream Life
"From the Archives"
47WeeWind is offline   Reply With Quote
Old 09-04-2007, 07:02 PM   #10
Got gandkids?
Jim;
Thanks!
Greg
Nice goin' Greg! Glad to hear it worked out for you. You can read about adding pic's here: http://www.airforums.com/forums/f138...eds-31829.html I'm sure there are many who would love to see a step-by-step.
www.nesa.org
Air No. 6427
Wondering what kind of glass to use for replacing all windows in 1958 Traveller williamhenshall Windows & Screens 3 08-19-2007 07:15 PM
Water leak panoramic windows Andy Fay Windows & Screens 16 01-05-2007 08:33 AM
Windows Inland RV Center, In Windows & Screens 1 04-20-2004 06:14 AM
Caravel windows susan martin 1966-68 Caravel 1 08-21-2002 08:43 AM
Motorhome Windows thenewkid64 Airstream Motorhome Forums 10 03-19-2002 12:09 PM
