Old 08-02-2011, 03:04 PM   #1
1997 25' Safari
Celina , Ohio
Broken window in our Safari.
While parked, we lost the road side crank-out window of our 97 Safari. A million pieces of shard glass in the driveway is all that remains. According to AS at Jackson Center, the manufacturer is no longer in business. That
would be Creation Glass of Elkhart, In. Anyone know another supplier that
I could go to ? The window that broke is approx. 8X30 dark tint or smoked. I haven't given up on Airstream yet. Is it possible to have one made by any glass company. Anyone have any experience in this area? Here's hopeing AS comes through for me....
tinhut is offline   Reply With Quote
Old 08-02-2011, 11:10 PM   #2
1985 31' Excella
Fresno , Texas
If the frame is good you can probably get the glass made. You would need to look for a Tempered Glass company. I am not familiar with your window. It sounds like a vista view but they don't open. You might post a photo. I know a place that can make a tempered panel but only with a architectural glass stamp. They made one for my insulated glass panel a few months ago. I had a DOT stamp on outside glass and Architectural stamp on the inside. The ideal situation is to have DOT stamp and they cost the manufacture thousands of dollars.
Wsmith is offline   Reply With Quote
Old 08-03-2011, 05:42 AM   #3
overlander63's Avatar
1993 21' Sovereign
Colfax , North Carolina
You could take it to Jackson Center, and have them replace the window with one that's currently available.
Old 08-03-2011, 06:03 AM   #4
Silverexpress's Avatar
2000 27' Safari
Suwanee , Georgia
Send a message via AIM to Silverexpress
I agree, take to Jackson Center and get the deal done. Then enjoy your Airstream!
John & Robin
99 27' Safari
AIR #34494
Living the Airstream Life:
Silverexpress is offline   Reply With Quote
Old 08-03-2011, 07:32 AM   #5
CanoeStream's Avatar
St. Cloud , Minnesota
Colaws, the RV boneyard in Missouri, might have an Airstream on the lot with similar windows.
A picture of this window style would be nice.
5 meter Langford Nahanni
Old 08-03-2011, 09:34 AM   #6
Ready-to-Travel
pmclemore's Avatar
2012 30' International
Walkerton , Virginia
Hiya, JIm - sorry to hear you lost your window. What happened? Too much heat and the adhesive let loose or something?
Pat
Somebody, please, point me to the road.
AIR 3987
TAC VA-2
WBCCI 4596
pmclemore is offline   Reply With Quote
Old 08-03-2011, 11:56 AM   #7
1997 25' Safari
Celina , Ohio
Canoe Stream....where is Colaws ? We will be in Hermann, Mo. next week.
Old 08-03-2011, 12:05 PM   #8
SilverCottage's Avatar
2007 27' Safari FB SE
LONDON , ON
Let me google that for you
SilverCottage is offline   Reply With Quote
Old 08-03-2011, 12:09 PM   #9
1997 25' Safari
Celina , Ohio
Hi PM. guess it was all the heat we've been having lately. Even had the AC running to keep the inside cool. Big surprise to see glass all over the driveway. I found a local supplier that can make me a 8X30 tempered smoked for about $50. Airstream has not found a replacement as of yet. They suggested I replace the entire window which would be mega bucks. The install would be up to me to do and I am not a glass man yet. Problem is getting the remaining slivers of glass out of the 3 "c" channels that hold the pane in place. No heat as it may cause the larger window to explode. I need suggestions from someone who has been through this before. Help please !!! I have two fingers cut already.
Tinhut
Old 08-03-2011, 12:39 PM   #10
cms4140's Avatar
Birmingham , Alabama
I can relate to this too...
-Chris
cms4140 is offline   Reply With Quote
Old 08-03-2011, 01:23 PM   #11
timmaah's Avatar
1999 25' Safari
On , the road
I would probably take a flat head screw driver and hammer, then gently tap the bits down the channel and out one of the ends.
timmaah is offline   Reply With Quote
Old 08-03-2011, 03:27 PM   #12
1997 25' Safari
Celina , Ohio
Timaah, unless I hear from AS soon, thats exactly what I am going to do. In addition I will apply window putty around all the bits of glass remaining
and of course Don a pair of safety glasses.The adhesive has a very tight
grip on the remaining particles of glass. Hopefully the putty will keep the fragments in check. I'll let you know how it goes. Right now I'm not a happy camper.
Tinhut
Old 08-03-2011, 03:35 PM   #13
cms4140's Avatar
Putty sounds like a good idea. I used hd shop vac and painters tape when I had this experience last week. Good luck with AS customer service.
Old 08-03-2011, 05:03 PM   #14
1997 25' Safari
Celina , Ohio
I googled Colaws today, maybe they will have the window I need. Will advise if they respond. Really though, I'm banking on AS to come through as our home base is only
35 miles away from AS factory. Been there many times, even before we bought our Safari. Can't get enough of that place.
AS280 - Front (driver) sliding window latch dalefox Classic Motorhomes 14 09-13-2018 08:05 PM
R & R Argosy wrap window Michael W Windows & Screens 4 09-09-2011 07:42 AM
1969 Airstream Ambassador / Broken Rear Window pewalker1 Windows & Screens 0 07-05-2011 10:50 AM
Rear window leak fixed! Really? I think so. 1964 GlobeTrottin 1960 - 1964 Globetrotter 0 04-30-2011 05:42 AM
Replace missing front window with jalousie? Cruisette Windows & Screens 6 03-31-2011 04:23 PM
