08-02-2011, 03:04 PM
1997 25' Safari
Celina
, Ohio
Broken window in our Safari.
While parked, we lost the road side crank-out window of our 97 Safari. A million pieces of shard glass in the driveway is all that remains. According to AS at Jackson Center, the manufacturer is no longer in business. That
would be Creation Glass of Elkhart, In. Anyone know another supplier that
I could go to ? The window that broke is approx. 8X30 dark tint or smoked. I haven't given up on Airstream yet. Is it possible to have one made by any glass company. Anyone have any experience in this area? Here's hopeing AS comes through for me....
08-02-2011, 11:10 PM
1985 31' Excella
Fresno
If the frame is good you can probably get the glass made. You would need to look for a Tempered Glass company. I am not familiar with your window. It sounds like a vista view but they don't open. You might post a photo. I know a place that can make a tempered panel but only with a architectural glass stamp. They made one for my insulated glass panel a few months ago. I had a DOT stamp on outside glass and Architectural stamp on the inside. The ideal situation is to have DOT stamp and they cost the manufacture thousands of dollars.
08-03-2011, 05:42 AM
Retired.
, At Large
You could take it to Jackson Center, and have them replace the window with one that's currently available.
08-03-2011, 06:03 AM
2000 27' Safari
Suwanee
, Georgia
I agree, take to Jackson Center and get the deal done. Then enjoy your Airstream!
John & Robin
99 27' Safari
AIR #34494
Living the Airstream Life:
08-03-2011, 07:32 AM
St. Cloud
Colaws, the RV boneyard in Missouri, might have an Airstream on the lot with similar windows.
A picture of this window style would be nice.
08-03-2011, 09:34 AM
Ready-to-Travel
2012 30' International
Walkerton
, Virginia
Hiya, JIm - sorry to hear you lost your window. What happened? Too much heat and the adhesive let loose or something?
Pat
Somebody, please, point me to the road.
AIR 3987
TAC VA-2
WBCCI 4596
08-03-2011, 11:56 AM
1997 25' Safari
Celina
, Ohio
Canoe Stream....where is Colaws ? We will be in Hermann, Mo. next week.
08-03-2011, 12:05 PM
2007 27' Safari FB SE
LONDON
, ON
Let me google that for you
08-03-2011, 12:09 PM
1997 25' Safari
Celina
, Ohio
Hi PM. guess it was all the heat we've been having lately. Even had the AC running to keep the inside cool. Big surprise to see glass all over the driveway. I found a local supplier that can make me a 8X30 tempered smoked for about $50. Airstream has not found a replacement as of yet. They suggested I replace the entire window which would be mega bucks. The install would be up to me to do and I am not a glass man yet. Problem is getting the remaining slivers of glass out of the 3 "c" channels that hold the pane in place. No heat as it may cause the larger window to explode. I need suggestions from someone who has been through this before. Help please !!! I have two fingers cut already.
Tinhut
08-03-2011, 12:39 PM
Birmingham
, Alabama
I can relate to this too...
-Chris
08-03-2011, 01:23 PM
1999 25' Safari
On
, the road
I would probably take a flat head screw driver and hammer, then gently tap the bits down the channel and out one of the ends.
08-03-2011, 03:27 PM
1997 25' Safari
Celina
, Ohio
Timaah, unless I hear from AS soon, thats exactly what I am going to do. In addition I will apply window putty around all the bits of glass remaining
and of course Don a pair of safety glasses.The adhesive has a very tight
grip on the remaining particles of glass. Hopefully the putty will keep the fragments in check. I'll let you know how it goes. Right now I'm not a happy camper.
Tinhut
08-03-2011, 03:35 PM
Birmingham
, Alabama
Putty sounds like a good idea. I used hd shop vac and painters tape when I had this experience last week. Good luck with AS customer service.
08-03-2011, 05:03 PM
1997 25' Safari
Celina
, Ohio
I googled Colaws today, maybe they will have the window I need. Will advise if they respond. Really though, I'm banking on AS to come through as our home base is only
35 miles away from AS factory. Been there many times, even before we bought our Safari. Can't get enough of that place.
08-04-2011, 04:18 PM
1985 31' Excella
Fresno
The easy way to get the tempered chips cleaned up is using a box knife using gloves and simply putting it between the glass and frame and cut the sealer.
08-05-2011, 03:20 PM
1997 25' Safari
Celina
, Ohio
Went to Jackson Center yesterday, they confirmed that the lower jalousie window is not available as their supplier went OOB. Other option was to go with a complete new window frame and all. Cost is $210 plus labor to install. Colaws returned my internet message yesterday also, Don't want to go this route as to not knowing age and condition and will it be OEM. I want to keep the unit as original as possible, so I ordered new window. Chris was very helpful and ordered immediately. I should be ready to travel in four weeks. Maybe by that time the fix is in, all this super hot weather will be history. Thanks forum for your support. Anyone need an upper half roadside window with a missing lower half ?
Tinhut
08-06-2011, 09:37 AM
Ready-to-Travel
Walkerton
, Virginia
Well, glad to hear that your solution is on the way. Maybe we'll catch you on the road one of these days.
Pat
AIR 3987
TAC VA-2
WBCCI 4596
03-29-2014, 02:46 PM
1999 28' Excella
Frederick
, Maryland
Just in case someone is scrolling through this older thread. A company named Parkin purchased much of Creation Glasses old inventory. They have a website "http://creationwindows.net/page2.html" (I couldn't get this to work on a hyper link for some reason) you can find out if they have a part you need. Also, SOME Hehr pieces will fit these windows.
1999 28' Safari
2012 F150 Platinum Max Tow 7650 GVWR 3.73 Elec. Locking Diff.(Prev 2003 Dmax).
Honda EU2000i, Equalizer Hitch
AM Solar Panels 150W - 2 Trojan T 105 6V Batteries
KC3MAP
On internet forums, please research and separate the wheat from the chaff (including mine!)
