Old 08-14-2007, 12:07 PM   #1
1985 25' Sovereign
Rochester , Indiana
broken curved window curb side HELP
I have a 1985 25 ft air stream and I have a broken curved window on curb side. Has anyone replaced one with plexaglass and if you have how did you do it.
The 2 nd thing is , does any one have a replacement window that would fit and the knowlege to tell me how to replace one.
Charlie
574 835 2378
charliesclassic@comcast.net
charliesclas is offline   Reply With Quote
Old 08-14-2007, 02:42 PM   #2
1977 31' Sovereign
1989 34' Excella
Johnsburg , Illinois
Curved glass windows
My understanding these are available thru Airstream at any dealer. Not cheap. If you want cheap plastic you would have to slump form them over a non-thermally conducting buck that was the right shape. This would mean you would by acrylic or polycarbonate(Lexan) sheet and oven dry them. Then you would heat them up to near their softening temperature and drape and push them over the buck while not marring the surface. Allow them to cool to room temperature and they will keep their shape. You could do minor polishing after they are done and then finish edges or drill holes as required. Some plastic fabrication shops in larger cities might be able to do the job for you.
Old 08-15-2007, 11:01 AM   #3
1969 31' Sovereign
1951 21' Flying Cloud
Alex , Oklahoma
Front curb side wing window
Charlie
574 835 2378
Are you looking for the wing window? single or double glass?
1969 Sovereign
1951 Flying Cloud SS#7062
AIR #18751
CJ of Okla is offline   Reply With Quote
Old 08-16-2007, 06:53 AM   #4
1985 25' Sovereign
Rochester , Indiana
1985 25' window
Hi
the window is the curved curb side window and I am not sure but think it is a double( .1870) thw window has the dark rock shield in fromt of it . the window is the one on the in side behind the curtins.
charlie
Old 09-02-2007, 02:32 PM   #5
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
Just got back from my 1st long trip (1 month) with the 71 Tradewind. 2nd Day out one of the wing windows blew out. (I thought it was from a passing gravel truck) 3rd day out the 2nd wing blew out. The road was a little bumpy but there was no obvious cause. I have heard some wing windows are prone to this. Both were single pane and very, very, very thin. Somewhere between 1/16 and a 1/32 judging by the shards. So, I have had duct tape and cardboard windows for the rest of the trip with no other major incidents.
I would like to find out more about replacing with Lexan for $ reasons.
Can I remove the center vertical frame piece and slide the Lexan in from the center to the side or do I need to take out all the rivets and the frame? Any way to do it with out pre slumping the Lexan. maybe with a heat gun? I have not found a Lexan source locally. Any suggestions?
Old 09-02-2007, 02:57 PM   #6
Desert Fox
1985 31' Sovereign
Tucson , Arizona
Talking Charlie
Hi,
Try Inland R.V. yhey have replacements. My exploded sitting at home. The cost from a AS dealer was 750 dollars. Lexan schould work as well unles you are a purist AS owner. Next time it happens lexon is for me. To keep it from happenig again I put a blaket over the front windows. I have traveled twice to Alaska with no problems.
Regards from Russell hot and sunny Tucson Az.
RUSSELL is offline   Reply With Quote
Old 09-02-2007, 03:03 PM   #7
Lumatic's Avatar
1993 34' Excella
Images: 16
Anyone know what years will also fit a 71?
Andy, if you're listening, I like your comment from an earlier thread something like "like people, sometimes things break with no explanation".
Old 09-02-2007, 03:08 PM   #8
Your Insurance company will pay for broken windows.
Typically, since Lexan is flexible, they will blow out when traveling when they are in the front, unless they are protected with a Rockguard.
Old 09-02-2007, 03:09 PM   #9
overlander63's Avatar
1993 21' Sovereign
Colfax , North Carolina
1970-1980 or 81.
1969 wing window is similar, but is flat on bottom (right and left are different parts), the other years fit either side.
Old 09-02-2007, 03:42 PM   #10
Wing windows are now made to fit from 1970 to July 1999.
Depending on the year, some trimming may be necessary.
Wing windows are labeled left and right.
Old 09-02-2007, 03:43 PM   #11
1969 25' Tradewind
Charlestown , Rhode Island
Safari Tim posted a really good step by step instruction guide with pictures, a while ago, on replacing these windows.
My husband used it last spring after both our front windows blew out. He found it extremely helpful.
I'm not sure what the post was called, but I'm sure you could do a search for "lexan window replacement" or something similar, and find it.
JenandGC is offline   Reply With Quote
Old 09-02-2007, 03:45 PM   #12
Originally Posted by RUSSELL
Hi,
Wing windows cost less than half of a wrap window.
Over $700.00 is correct for a wrap window (40 inches wide).
Tempered glass windows indeed can break when the trailer is parked, seemingly without a reason. Historically, the breakage is caused by a grain of sand or two, penetrating the surface temper. Unfortunately, you cannot see that with our eyes. When that happens, and who knows when it happened, enough changes in temperature between night and day, will eventually make the window just shatter. It could take years before the glass would shatter.
We know what the cause is, it's just impossible to predict the failure in time.
The only real prevention, is to have a Rockguard cover the front window or windows as the case may be.
Most insurance companies cover glass losses with no deductible, unless the loss was caused by a collision.
Old 09-02-2007, 04:57 PM   #13
1993 21' Sovereign
I have found out the windows are different, right and left. The glass itself may possibly be the same, but is not worth the effort to take out of the frame and reinstall, even if it fit.
Andy, I thought the wing windows were wraparound after 82 or so, like the old Argosies.
Old 09-02-2007, 10:53 PM   #14
Not so.
Wrap windows are about 40 inches wide.
Wing windows are only 14 inches wide.
Both are still used.
Argosy trailers never used wing windows, only the wraps were used, in the front and sometimes in the rear too.
Some classic motorhomes used wrap windows in the rear, or just a rear window.
Window Seal niftypkg Windows & Screens 15 03-10-2018 05:48 AM
Oval Window Frame Replacement MikeMikeMI Windows & Screens 8 12-30-2007 10:49 AM
Curved side window replacement michel88 Windows & Screens 7 09-29-2006 09:20 AM
leaking around front window of 1969 Caravel David Henderson Leaks - Weatherstrips, Gaskets, Caulks & Sealants 0 10-27-2002 11:01 AM
side mirrors ALANSD Airstream Motorhome Forums 5 04-20-2002 07:38 PM
