Old 06-30-2007, 03:51 PM   #1
Stefrobrts's Avatar
1968 17' Caravel
Battle Ground , Washington
Images: 50
Broke my window!
This is entirely my own fault. I was using the gas trimmer around the house, and apparently it threw something right into my kitchen window! Ouch! All the more ouch knowing I did it to myself. And that now I have to get it fixed in time to go camping next weekend. Ugh...
Stephanie
Old 06-30-2007, 03:54 PM   #2
Aluminut
Silvertwinkie's Avatar
2004 25' Safari
. , Illinois
Aw Stef, sorry to see it. I know you have plenty on your plate lately. Hope it's a simple fix.
Old 06-30-2007, 04:05 PM   #3
Ganglin's Avatar
1971 27' Overlander
Central , Ohio
Images: 13
Hate when that happens. You might want the see post number 4 from Inland RV under this thread.
http://www.airforums.com/forums/f454...ion-33330.html
Old 06-30-2007, 04:18 PM   #4
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Ow! Stef, that's not a Corning window, is it?
Old 06-30-2007, 06:13 PM   #5
Stefrobrts's Avatar
1968 17' Caravel
Images: 50
Yup, one of my original curved corning windows
Stephanie
Old 06-30-2007, 06:25 PM   #6
silver 67's Avatar
1967 30' Sovereign
Leavenworth , Kansas
We feel your financial pain....
because we just replaced two curved and two flat windows. Vintage sent them quickly though, so maybe you can be on the road before you know it.
At least it looks as though your AS is covered and you won't get rain inside.
Beth and/or David
67 Sovereign, double bed, rear bath-"Moby"
2005 Dodge Ram 2500 Hemi, Quad Cab-"Ahab"
"Vintage trailer, vintage owners"
silver 67 is offline   Reply With Quote
Old 06-30-2007, 08:14 PM   #7
Stefrobrts's Avatar
1968 17' Caravel
Images: 50
I just looked up the price! That's a $200 piece of glass!
Yes, luckily the trailer is safely under it's vinyl carport, so it will be dry under there.
I'm going to do a search on putting plexi in. One of my other big windows is plexi already. I really don't have a problem with it, compared to an unexpected $200 repair.
Stephanie
Old 06-30-2007, 08:30 PM   #8
1968 22' Safari
1982 28' Airstream 280
Gloucester , Massachusetts
You should use Lexan, I had a window repair done by the PO and it cracked on me while closed and pulled tight against the curved window opening.
Lexan is very flexible and is what I now have on that window.
ajheinonen is offline   Reply With Quote
Old 06-30-2007, 09:00 PM   #9
InspectorDread's Avatar
1987 34' Excella
Mobile , Alabama
Just out of curisioty, has anyone ever suffered a broken or cracked Vista Veiw window from towing. I'm about to pull my 34' monster 500 miles and I'm worried about being hit by flying debris. I even thought about covering the windows with cardboard and duct tape. Has anyone else had experience with this?
InspectorDread is offline   Reply With Quote
Old 07-01-2007, 01:51 AM   #10
3Ms75Argosy's Avatar
1975 Argosy 26
1963 24' Tradewind
Seattle , Washington
Ugh! So sorry Steph. Look at this way.... it's cheaper to replace even the glass than fix the dent in the side if it hit the aluminum.....
Good luck! Power to Alki!
Marc
Old 07-01-2007, 04:41 AM   #11
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
I have never seen a Vista View broken in towing (not to say it hasn't happened to someone somewhere) I think it is a long shot because of where they are located. I did manage to break one of mine while I was removing the interior pane as part of a reseal and cleaning process...$250 and 57 rivets to repair not part of the restoration plan!
Aaron
WBCCI #XXXX AIR #2495
Old 07-01-2007, 08:06 AM   #12
2005 22' International CCD
Buckhorn , Ontario
Images: 59
Send a message via Skype™ to GT1963
For quick fixes on the road - Lexan is great - but for the originality glass is the only route if you can get (save the 69 wing windows) you can pretty much get any replacement.
We travel with an emergency closure now that you can quickly duck tape on until you can get to a glass store - once we used a boot matt and another time we fashioned a piece of stock pressboard 1/4" cut to size of the wing windows. Came in real handy cause we did loose a window on that trip too.
Everything will be alright in the end. If it is not alright now, then it is not the end.
GT1963 is offline   Reply With Quote
Old 07-01-2007, 08:25 AM   #13
BIGED52's Avatar
1967 22' Safari
MILAN , Illinois
Shattered Dream
Stef, Sorry to hear of the loss of a Corning window! The fact that you do have the moulding from the glass will help when you replace it with Lexan. Plexiglas is NOT an option! It will flex too much and you will have moisture (rain) find its way in around your frame and seal. Go to a local glass shop with the moulding and have them insert a Lexan replacement of the same thickness as the original Corning glass. Make sure to tell them that the moulding is slightly curved to fit the profile of the trailer and not to try to straighten/flatten it out! Happy Trails, Ed
1967 Safari Twin "Landshark" w/International trim package
1999 GMC Sierra 1500 SLT
FORUMS MEMBER SINCE 12/16/2004AIR#7110
"My tire was thumping, I thought it was flat. When I looked at the tire, I noticed your CAT!" Burma Shave
BIGED52 is offline   Reply With Quote
Old 07-05-2007, 10:52 PM   #14
Stefrobrts's Avatar
1968 17' Caravel
Images: 50
Well, I shelled out for the expensive glass window to replace the gaping hole in the side of my trailer. It arrived today. Only problem is I'm having trouble removing the top channel so I can clean it out and put the new glass in. There are aluminum tabs sticking up on each end to prevent the window from sliding out sideways. It won't lift up and come off the hinge. The instructions on vintage trailer supply say only part of it will come off, and you have to pry them apart. So I have cleaned out all the broken glass and I just need to get the channel apart to finish cleaning out the old tape and install the new glass. I'll be getting double stick tape to mount the glass from the glass shop tomorrow. But what's the trick to getting that top channel apart?
Stephanie
Window latch dilemma maxandgeorgia Windows & Screens 5 05-18-2018 10:35 AM
Oval Window Frame Replacement MikeMikeMI Windows & Screens 8 12-30-2007 10:49 AM
1974 Excella front window docu post john hd 1973-1974 Excella 500 22 08-06-2004 01:53 PM
Front Wing Window Repair Charles D. Bennett Windows & Screens 0 08-10-2002 06:04 PM
Window Frame Removal 64GT Windows & Screens 4 04-09-2002 12:40 PM
