Old 02-24-2011, 11:38 AM   #1
Viper2's Avatar
Jay , Maine
Bathroom window help
I ordered a new bathroom window and got it yesterday. However after 3 hours of workinging it. I just can not get the hinge into the frame. Is there some trick to this. The ends go in, but the center wont?
Viper2 is offline   Reply With Quote
Old 02-24-2011, 12:46 PM   #2
airdreamers's Avatar
2008 28' International
Venice , Florida
Images: 14
Without seeing the hinge, it sounds to me that the center of both the window frame and sash frame do not line up. Put a straight edge on both to determine the non- ailment, they both should be perfectly straight. You may have to open the center of the hinge slightly to allow the 2 pieces to fit into each other.
Hope this suggestion helps.
Bill and Janice, We're lovin' it! (Airstreaming)
Airdreamers
WBCCI #8880
AIR #41310
airdreamers is offline   Reply With Quote
Old 02-24-2011, 12:54 PM   #3
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
Check the J hinge does not have any dents. Lift the window way up past 90 degree angle to the window frame.
Lumatic is online now   Reply With Quote
Old 02-24-2011, 02:57 PM   #4
Splitrock's Avatar
Sioux Falls , South Dakota
I had all my windows out to install new gaskets. I spent more time getting one of the side windows back in than I spent on all the rest combined. Andy wrote a good tutorial on one of the threads. It helped a lot. My addition to the installation technique, was to lube both sides of the hinge with Slipit. It was the miracle I had been praying for. Got it from Rockler.
I installed them all alone except for the two end windows. The farmer's daughter helped me with both of those and they went in quick and easy. No force, no pushing or prying on mine. Just the Andy method technique and Slipit and they went right on.
AS280 - Front (driver) sliding window latch dalefox Classic Motorhomes 13 01-05-2012 06:41 PM
19' Airstream Bambi bathroom Sactown 2005 and newer - Bambi all models 6 04-06-2011 08:02 PM
Got my window out. Now what? Breadbug Windows & Screens 3 01-23-2011 07:27 PM
Front window leak fix? BarnacleBill Flat-Front (Cutter, Clipper, XC, XL & Skydeck) Motorhomes 7 01-18-2011 05:04 PM
1950 Flying Cloud Needs Window Replacement happy123 Windows, Doors, Locks & Vents 2 01-10-2011 05:56 PM
