Old 03-06-2008, 10:46 AM   #1
vhord's Avatar
Images: 96
Are new window frames available?
I have a 1970 27' Overlander. The PO removed most of the frame on the front window in order to install a window A/C. Am I going to have any luck locating the missing frame and operating parts?
vhord is offline   Reply With Quote
Old 03-06-2008, 10:49 AM   #2
InsideOut's Avatar
1956 22' Safari
Conifer/Evergreen , Colorado
Images: 108
You may want to check with Colaw RV Salvage...it's sort of a graveyard for Airstreams.
Shari
Old 03-06-2008, 11:08 AM   #3
Attachment 55618
Attachment 55619
The window frame is riveted into the shell.
Your photo shows it's still there.
Replacement windows are called "sash and glass."
If you simply order a replacement "sash and glass", that will solve the problem.
You should check the bottom of the frame and see if it still has the "latches," like the other opening windows have.
Old 03-06-2008, 11:40 AM   #4
vhord's Avatar
Images: 96
Shari,
Thanks for the lead. I will check with them.
Andy,
Thanks for the terminology clarification. You would think that I would know that after 30 years in the retail hardware business.
The operating hardware is missing. They left the two handles laying on the floor but nothing else. Does Inland have the sash and glass? It is rectangular and measures approx. 24" tall x 44" wide.
I will have to wait to remove and check out the rest of the frame. For now I am enjoying having the makeshift A/C to use while removing the floor here in southeast Texas.
Old 03-06-2008, 11:45 AM   #5
Shari,
Andy,
We have the latches and the window in stock.
Old 03-06-2008, 02:20 PM   #6
1977 31' Sovereign
Panguitch , Utah
Does anybody know how we can set up a drive up window in a 1977 airstream. We are converting into a coffee trailer
RickR is offline   Reply With Quote
Old 03-06-2008, 02:26 PM   #7
To create a wide window opening, requires structural changes.
The vertical sides of that opening, must match the shape of the shell, both for the shell and door.
It also must be properly sealed to keep out rain.
How it's latched closed, is also important, since the shell twists when the trailer hits bumps.
It is suggested that you have someone do it, that has shell modification experience.
Old 03-06-2008, 02:36 PM   #8
1977 31' Sovereign
Panguitch , Utah
Was thinking I could just use the existing size maybe combine the larger top and smaller bottom window into one opening, but same width.
Didn't know if there would be a window available that would curve with the body and still lift up for service.
Old 03-06-2008, 04:24 PM   #9
Airstream does not have a window tall enough, that opens, that will replace an opening window and a stack window, with one window.
Old 03-06-2008, 05:30 PM   #10
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
vhord, the windows in 69 through at least 75 have basically the same dimensions. I recently replaced my front wing windows from my 71 with windows salvaged from a 75. There are some changes in construction, mainly single pane or double pane and frame thicknesses but the width and height should be the same. My new to me 75 windows also mate perfectly with the marriage bar that connects the wing windows to the center window frame. Some of the later 70s windows also have slightly different window openers (that work easier) which requires a different position of slots in the screen frame. If you are replacing a window with another year window that has a different thickness frame the old plastic window trim inside the trailer may not fit right so try and get the window, screen frame and the trim. The bottom line is you may very well be able to find a used replacement from a different year that will fit for a lot less moolah than a new replacement.
Old 03-06-2008, 05:36 PM   #11
InsideOut's Avatar
1956 22' Safari
Images: 108
Lightbulb
I wonder if you could adapt one by turning it 90-degrees to get the height? I don't know...just trying to think of other options ~ outside the box!
Shari
Old 03-07-2008, 06:04 AM   #12
vhord's Avatar
Images: 96
Lumatic,
Thanks for the info. I am also missing the inside plastic trim and screen. I have several months before I have to replace the window so maybe I will get lucky and find a used one in that time frame. I will be replacing the entire floor, insulation, and most of the cabinetry so that will take a couple of weeks. Ha!
If anyone runs across a A/S in that time frame being parted out I would appreciate a shout.
need help with window frames whistler Windows & Screens 7 06-09-2014 11:13 AM
Rivets for window frames Lumatic Windows & Screens 5 04-30-2008 12:16 PM
Painting Window Frames Bfrank Windows & Screens 1 06-25-2007 10:23 AM
Aluminum window frames mcostanzo Windows & Screens 0 04-16-2003 03:42 PM
MH side window frames Bfrank General Motorhome Topics 6 04-15-2003 11:15 AM
