Old 06-02-2006, 11:21 PM   #1
1965 17' Caravel
Aldergrove , British Columbia
Anyone know if Tempered Glass was used?
We went to a glass shop to get a replacement pane for our little kitchen window after disassembling it to re glaze and finding the edges all chipped up. My wife (who built window units in a past life) tells me it must be a replaced pane as Airstream surely wouldn't use glass cut like that.
The glass shop asked us why we weren't replacing with tempered glass - no idea, but none of our windows are stamped "tempered".
Anyone know if tempered glass was ever used?
Thanks!
Frostyone is offline   Reply With Quote
Old 06-03-2006, 01:41 AM   #2
BIGED52's Avatar
1967 22' Safari
MILAN , Illinois
Replacement glass
Frostyone, When you are replacing any of the old glass there are those that will tell you to keep it original and use the same glass as was in the frame before. I think the correct thing to tell you would be to have the replacement glass made to fit from heat tempered glass. The reason is safety! The heat treated glass will be much more shatter resistant and will pellet if it does break rather than ordinary glass which tends to shard! It is not only better for your personal safety but for the safety of your trailer and the things you have inside it. Also automotive grade heat tempered glass wasn't really made available back then. All the 66',67', and 68' model year trailers had Corning chemically tempered glass install by the factory as an increased safety item way back then, and new trailers all come with heat tempered glass these days! In the end it is a personal choice. I will tell you that I had to replace all the plexiglass/lexan for my trailer and I was lucky to get new heat tempered glass to fit my trailer from VintageTrailerSupply. However, the windows in my coach are curved or I would have purchased them from the local glass shop. I wish you luck with your project and keep us updated. Ed
1967 Safari Twin "Landshark" w/International trim package
1999 GMC Sierra 1500 SLT
FORUMS MEMBER SINCE 12/16/2004AIR#7110
"My tire was thumping, I thought it was flat. When I looked at the tire, I noticed your CAT!" Burma Shave
BIGED52 is offline   Reply With Quote
Old 06-03-2006, 04:05 AM   #3
Use regular plate glass-
I'd use untempered regular plate glass, unless I was replacing ALL the glass. You're only talking about 1 pane, not the whole trailer, and its not that big of a deal to have one thats tempered.
The safest glass to install is tempered safety glass, with an applied layer of window tint film- which is available in totally clear as well as different shades of smoke, bronze, and metallized reflective tint. The tint will hold together the shattered glass if something happens where it breaks in transit. Otherwise, the shattered glass falls, allows no security, and requires immediate attention, which may not be available.
Tempered glass is harder to break, but also has some negative characteristics, such as temperature changes shattering it, and when you want to shatter tempered glass- you can hit it with a baseball bat and it won't shatter, but tap it in the corner with a spoon and hardly any pressure, and it shatters completely. Installation in the frame must also be done carefully- any contact with a metal edge will result in shattering when you start vibrating, bouncing your trailer along country roads.
The other easy and less expensive alternative, is laminated safety glass- this is what is used on your front windshield of your car- the sides have tempered. The glass is basically 2 layers of plate, with a layer of plastic laminated inside- when you look at it from the side, you can see its composition. Its made so that when it gets broken, it stays together, and glass shops usually stock it and can cut it and sell it immediately, where tempered has to be patterned, cut, sent out for heat tempering, and returned. I had a place that was huge and did it in house, but most shops send it to a big tempering facility, and they have a minimum charge that will far exceed the value of the single window you're replacing.
Be sure that you get the same "color" as a lot of shops stock different tints- even though they don't look like they are- its going to show even a mild tint when you install it- order clear. And I'm not so sure Airstream was installing perfectly polished edged glass on our trailers- especially when they have an assembly line and quotas to meet- if it gets covered, the edge is not a quality concern...
Good luck and let us know what you choose.
millionairstream is offline   Reply With Quote
Wondering what kind of glass to use for replacing all windows in 1958 Traveller williamhenshall Windows & Screens 3 08-19-2007 07:15 PM
Glass Wax InsideOut Cleaning, Stripping & Polishing 21 09-01-2003 02:31 PM
glass dealer,manufacturer ALANSD Link Archive 0 09-02-2002 07:37 AM
How to remove the glass from windows? Andy R Windows & Screens 2 06-19-2002 09:30 AM
What type of glass should be used on a 60s AS windows? Andy R Windows & Screens 1 06-19-2002 09:23 AM
