Some of the older trailers have a spline that you can remove and then put in a piece of plex or lexan to fit the hole. If you want to replace with a new one, you can do that but the replacement will have only one pane which is a good thing because these hotdog shaped windows tend to have leaks.
1970 23' Safari
North Vancouver
, British Columbia
I think my street side has the spline, but my curb side doesn't seem to be the same. I think I might have to drill out the rivets on the outside, but that doesn't seem right.
Well can you remove whatever inner retaining lip that is there already? On some windows you have to remove the window frame (by drilling out rivets) and pull the left and right half of the frame apart. The halves are conected using a steel bar riveted to each side of the frame. It also acts like a key to align the two halves.
You might be into less money with a buck riveting setup. You should be able to remove the inner skins and get to the back side. The rivet shavers are pricey and the buck rivets are better.
1970 23' Safari
North Vancouver
, British Columbia
I think what I'm going to do is repair the window with regular pop rivets to last me through next weekend when I plan to use the trailer, and then replace the rivets with either buck or shaveable depending on what I can find locally.
I was worried earlier about having to drill out these rivets, but I'm feeling pretty good about it now. I might actually know someone with a rivet shaver.
