Old 12-22-2018, 05:29 PM   #1
pjshier's Avatar
2017 27' International
Wasilla , Alaska
@(%&# broken door window/burglary attempt
Apparently our secure covered storage is only one of the two. Stopping by today to get some data for a possible converter upgrade, I see the window in the door broken, the metal screening cut, the fabric bug screen ripped, and the welded cross piece that holds the screen door slide for access to the locks from inside is slightly bent. Apparently no access gained to the trailer, no other external or internal damage. Police reports filed, yard owner notified. Relocating to our home tomorrow.
Questions: 1. there are no Airstream dealers in Alaska, so how to get the window replaced? (Alaska Streamers feel free to share your local knowledge of folks that know the species.) Not sure, but it looks like solid rivets may need to be drilled out and replaced.
2. The bent cross piece and cut metal screen - does that mean a whole new screen door?
All insured. Biggest concern is to get all repairs done correctly. Thanks in advance for your condolences and suggestions. Grateful it was not worse. Certainly made us angry. But I consider this a "first-world" problem that has a feasible solution.
2017 Int'l Serenity 27FB
2017 F350 oil burner
pjshier is offline   Reply With Quote
Old 12-22-2018, 08:02 PM   #2
Caffeinated's Avatar
2015 27' Flying Cloud
Portland , Oregon
Well that sucks. Good luck. Maybe call AS at Jackson Center and send them pics and they could tell/send you the right parts?
Mike
2015 27ft FC FB
WBCCI #3960
2019 F150 ecoboost
Caffeinated is offline   Reply With Quote
Old 12-22-2018, 08:02 PM   #3
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
Always bad news to hear about a thief. Maybe the perpetrator is on camera somewhere.
I believe the extent of the damage to your new Airstream warrants a trip to an Airstream shop that does body repair work. It's going to be a hassle for you, but it will get repaired as good as new eventually.
David
WBCCI #8607
VAC Region 11
Link to my 1975 Overlander Improvement Journal:
https://www.airforums.com/forums/f17...ml#post2053792
Old 12-22-2018, 08:33 PM   #4
Overland Adventurer
AtomicNo13's Avatar
2009 34' Panamerica
Telluride , Colorado
Way cheaper to learn to buck rivet than is a road trip to the factory.
That window start to finish is at most a few hours work. After this, you're ready for anything!
Re screening the door is cake!
Old 12-23-2018, 09:23 AM   #5
2015 25' FB Flying Cloud
Huntley , Illinois
Northwest adventures
If you can ferry your AS to Seattle (Covington) The AS dealer there can repair your unit. They have excellent service. Highly rated repair. Better than factory now. Factory is overwhelmed with repair needs. We have used them. Call the service manager there. He can tell you what can be done and the time frame. They might be able to order parts ahead for the repair
cegardner is offline   Reply With Quote
Old 12-23-2018, 10:52 AM   #6
59' Globester
twolanehwy's Avatar
1959 18' "Footer"
1957 26' Overlander
Three Rivers , California
Ya mean the criminals are even up in the great white north?
Then there is nowhere to escape anymore.
I'm sorry to read this as I'm sooooo tired of worrying about thiefs.
It's just sad that America has lost it's moral compass.
I just retired to Sierras from 40 years in SF. That place has become the criminals paradise. So far so good up here.
Wish you the best.
twolanehwy is offline   Reply With Quote
Old 12-23-2018, 11:01 AM   #7
pjshier's Avatar
Wasilla , Alaska
Thanks for the replies. Brining the unit home today, and further inspection. Ideas welcome.
Name:	broken window (2).jpg
Old 12-23-2018, 11:22 AM   #8
Raminc's Avatar
Wasilla , Alaska
pjshire,
I'm a neighbor in Palmer Ak. This kind of thing has been happening more often around the valley than ever. If you need help I would be willing to give you a hand. I'm pretty handy and there's a lot of riveting and metal straightening that I think can be done to save from having to order a new door. Which storage yard was you using? Our Airstream sits outside our bedroom window with a security camera watching. I'd be really pissed if I came home and found her damaged. If you want to pm me I'll give you my phone number so we can talk.
Man plans ... The Gods laugh
Raminc is offline   Reply With Quote
Old 12-23-2018, 12:11 PM   #9
Stream of Consciousness
2014 27' FB International
Snoqualmie , Washington
The only problem with AS Northwest (Covington) is the amount of backlogged work queued up at any given time. Just to get awning repair, it took a month. The previous year, we had minor repair work done and the nano sealer; it took 2 months. Just an FYI...
DTCOnyx is offline   Reply With Quote
Old 12-23-2018, 01:43 PM   #10
mefly2's Avatar
2015 25' FB Eddie Bauer
2013 25' FB Eddie Bauer
2012 20' Flying Cloud
Small Town , *** Big Sky Country ***
+1 for Airstream Adventures NW in Seattle (Covington) ...
Old 12-23-2018, 01:44 PM   #11
garry's Avatar
1969 31' Sovereign
Broken Arrow , Oklahoma
Not sure about the later models but when I replaced a window I was surprised to find the new window holes did not match and all new rivet holes would have to be drilled some halfway overlapping the old hole.
Since the gasket was still good I repaired the old window with Lexan
probably took me 3 hours start to finish hard part was putting the old window back together.
Kind of a PITA but better than re-drilling and having hundreds of holes.
I did not have the tool to smooth out the bullet rivets but a Dremel tool does a good job if you take your time.
Garry
Old 12-23-2018, 05:28 PM   #12
2007 27' Safari FB SE
La Pine , Oregon
Sorry to hear about your issues. I've found that those "storage" places are anything but secure.
I have a 16' cargo trailer. It was parked next to my AS in a friends driveway. One night the neighbor came over and said "do you know your cargo door is open?" (I had it locked as I had my ATV and a bunch of other stuff in it.
They cut the lock and stole a lot of stuff. So I decided I'd tow it to a new "Safe and Secure" storage lot that just opened. About 2 months after I moved it there, I got a call from the manager saying they thought maybe someone had tried to get into the cargo trailer (I was up on my property @ 70 miles away).
I drove down and when I checked the trailer, the bastards had cut both "security bars" that the locks latch onto. I was pissed and let the "secure" storage people know what I thought - they stated they had no responsibility for any loss or damage.
I had to drive over to Idaho to buy 2 new latching mechanisms since the trailer has a ramp and it would have flopped open if I'd tried to haul it to the dealer.
The reality is, if you have room on your property, anything is probably safer there than at any supposedly secure storage facility.
It was obvious to me that whomever did this had a unit at the storage place as you have to have a key code to get access and it's surrounded by fencing with razor wire on top. Any thief could simply rent a storage unit, then gain access at night (this one is available 24 hours/day) then make the rounds at night to steal whatever they want and lock the loot in their storage unit to retrieve at their leisure.
Fortunately, these a-holes didn't steal anything out of the trailer, though they probably would have if I'd been dumb enough to leave it there - I towed it to my property that same day after I got the replacement parts.
andyherman is offline   Reply With Quote
Old 12-24-2018, 11:14 AM   #13
pjshier's Avatar
Wasilla , Alaska
message sent.
Old 12-24-2018, 11:28 AM   #14
pjshier's Avatar
Wasilla , Alaska
A&E Storage on the Parks highway. When I called the police, the arriving officer said "Again?" When I called the storage yard folks - they sheepishly admitted there had been unauthorized entry under a fence at the rear of the property, which they thought they had solved with a snow berm.
We are definitely now working on a solution here at home. The rare subdivision around here with restrictive covenants, so I have to think about how to pull it off without going overboard. Most of the neighbors are in violation under the "no parked RVs, unless..." section. Just don't want to push it. My opinion: an AS in the yard classes-up the joint.
Now, it sits outside our bedroom window with motion lights and two energetic barking dogs. A&E had cameras, too, but my read of the attending officer was that the cameras might help make a case if they stumbled upon the perp in some other way. At the U, I was in charge of the U Police and the system of 500 cameras. 99% of the time they provide a record of what happened. But there is an undeniable prevention effect for those that can read the signs and aren't whacked-out on whatever.
I'll be on the phone later this week checking out parts availability and prices as a baseline for decision-making. The one tricky part i can't see an easy solution for is the thin metal screen panel in the upper screen door. Seeing as it was pretty easily cut out of the way - may not be necessary to replace it if it proves difficult. Still thinking a new screen door shipped here might be covered. More to come. Thanks heaps for the feedback.
No Help Yet. Second attempt. Broken Rectangular Fixed Window. algebrotha Windows, Doors, Locks & Vents 5 05-09-2017 05:56 PM
A&E awning modification attempt Belegedhel Awnings 10 08-15-2013 06:16 PM
Attempt to limit duplicate threads summerkid Forum Admin, News and Member Account Info 51 09-20-2006 01:51 PM
#2 attempt--any recommendations for a solar charger? Kistler Generators & Solar Power 6 02-16-2005 07:01 AM
I am going to attempt to adjust my window ipso_facto Windows & Screens 5 11-08-2003 09:08 AM
