Old 12-22-2011, 02:31 PM   #1
Aluminum Falcon Mechanic
Darkspeed's Avatar
1972 31' Sovereign
Wesley chapel , Florida
Alternate Window latch
southco model 62-10-21
About $12
McMasterCarr
Amazon - Amazon.com: Southco Inc SC-6211 Lift-and-Turn Compression Latch Grip Range .08 to .47 Pawl Forward - 1.25 to 1.66 Pawl Reversed, Southco Lift and Turn Latches: Industrial & Scientific
Ried
etc....
I am ordering one to test, but it seems to be the same specs and size as the OEM except for a slightly longer lever
Dont let the dogleg pawl fool you , it is much flatter on the 62-10-21 and there is the option of using your old pawl
Darkspeed is offline   Reply With Quote
Old 12-22-2011, 07:13 PM   #2
Ganglin's Avatar
1971 27' Overlander
Central , Ohio
Images: 13
Quite a savings over originals if they work out...
Old 01-03-2012, 10:34 AM   #3
Darkspeed's Avatar
1972 31' Sovereign
Skinny on the 12$ latch..
Works perfect with two requirements
1. use your old pawl
2. optionally trim the threaded pawl stem ( if required )
ID:	148187   Click image for larger version
ID:	148189   Click image for larger version
ID:	148191   Click image for larger version
'58 Hehr Window - Is this the correct window operator replacement? mello mike Windows & Screens 22 10-08-2012 08:49 AM
AS280 - Front (driver) sliding window latch dalefox Classic Motorhomes 13 01-05-2012 06:41 PM
Broken Window Repair Firstlight Windows & Screens 10 10-20-2011 08:45 AM
Rear window leak fixed! Really? I think so. 1964 GlobeTrottin 1960 - 1964 Globetrotter 0 04-30-2011 05:42 AM
Replace missing front window with jalousie? Cruisette Windows & Screens 6 03-31-2011 04:23 PM
