Old 12-20-2009, 04:07 PM   #1
Silverfoxrae's Avatar
1957 26' Overlander
Saint Augustine , Florida
Images: 45
air-?- jalousie windows for vintage TT
I've been digging but haven't come up with a thread--yet about this specifically, so I'll just ask.
I have several jalousie windows in the '47 Liner. Only the double set on the galley side are there-thankfully I have something to go by...
I'm guessing that more than likely I will be learning/copying how to build new ones to fill the three spaces on the door side, but I thought I'd ask for any suggestions as to where I might be able to find--ha ha--?
I so far see there's quite a lot of hardware from vintage trailer supply... and glass is a no-brainer. The big ovals in the front/back I should be able to have made by a glass shop- worse case scenario maybe an auto glass/windshield place...
Silverfoxrae is offline   Reply With Quote
Old 12-20-2009, 06:22 PM   #2
47WeeWind's Avatar
1948 16' Wee Wind
1953 21' Flying Cloud
Denver , Colorado
Images: 20
Air-O-Lite windows . . .
Originally Posted by Silverfoxrae View Post
... I have several jalousie windows in the '47 Liner. Only the double set on the galley side are there-thankfully I have something to go by... where I might be able to find [some]--ha ha--?
Hi Silverfoxrae:
The two windows on the street side of your '47 Liner [where your galley is located] are original and correct for your trailer. I call them stacked casement windows because each window pane opens separately from the other. But you must open the top window before opening the bottom window, and you must close the bottom window before closing the top window.
To me, your street side windows are not jalousie windows, which to me have many shorter unframed overlapping glass panes that open and close together. Jalousie windows were used in 1950s & 60s Airstreams, and usually were installed just forward of the door because the individual panes do not stick out far from the trailer body when the jalousie window is fully opened, making ingress and egress easier.
Your street side stacked casement windows were made by the Air-O-Lite Trailer Window Co. of Los Angeles, Calif. Air-O-Lites were used in Airstreams from 1947 to about 1950 and were also used in other 1940s travel trailers. To my best knowledge, no one reproduces them so you will have to either have find some used ones, a difficult task at best, or find practical substitute windows for the curb side [door side] of your Liner. Best of luck with your search.
There will be an informative and nicely illustrated article on 1947 and 1948 Airstream trailers in the upcoming Spring 2010 issue of Airstream Life magazine. This issue should be available in 2 months, so keep your eyes peeled for it.
Fred Coldwell, WBCCI #1510, AIR #2675
Denver, Colorado - WBCCI Unit 24
Airstream Life "Old Aluminum"
Airstream Life
"From the Archives"
47WeeWind is offline   Reply With Quote
Old 12-21-2009, 06:58 AM   #3
1957 26' Overlander
Images: 45
Thank you!!
Old 12-21-2009, 07:29 AM   #4
3streams's Avatar
1948 22' Liner
1949 24' Limited
Springs , Pennsylvania
We are considering remaking some of these window frames- since we have them on our '48, '49, and '50 and are missing or have some broken ones between the 3 trailers. We will keep you posted on how this works out.
April & Andy Hershberger
www.ClassicAluminumTrailers.com
3streams is offline   Reply With Quote
Old 12-22-2009, 12:20 PM   #5
1957 26' Overlander
Images: 45
Great! I hope they're easy ;-)
Jalousie windows stuck campngirl Windows & Screens 4 02-24-2011 07:18 AM
1973 Airstream 25' Trade Wind Land Yacht - Jalousie Windows Screen Fuzzy Pile Seal sysgenss Windows & Screens 1 05-25-2009 11:33 AM
Has Anybody ever tinted the windows on a vintage Airstream?? tvadman1963 Windows & Screens 5 04-15-2007 05:16 PM
vintage windows falling out--why? BevnCraig Windows & Screens 13 04-16-2003 06:23 AM
