Old 05-06-2004, 06:17 PM   #1
Tin Hut's Avatar
2005 28' International CCD
Pagosa Springs , Colorado
Adhesive for window gaskets
A few days ago someone asked about adhesive for attaching window/door gaskets. The 3M Super Weatherstrip Adhesive 08008 is typically used. You can find it at auto stores...other places. Here's a site that sells it for $5.99 per tube. http://www.autobarn.net/3mblacsupwea.html
"would you rather have a mansion full of money or a trailer full of love?"
Tin Hut is offline   Reply With Quote
Old 05-06-2004, 09:53 PM   #2
2005 22' International CCD
Buckhorn , Ontario
It was I ever amusing Tin Hut....Thanks - I will check out our local Auto Dealer instead of the Hardware store - If not our Canadian Tire might carry it too.
We have all the leaks under control - but would like to get the new seal on to keep the mosquitos at bay.
Thanks again
05ModPod is offline   Reply With Quote
Old 05-07-2004, 09:14 AM   #3
Tin Hut's Avatar
The mosquitos in Texas are too big to come through the window. They'll knock ono the door, but if you don't open it they can't get in.
Old 05-07-2004, 09:43 AM   #4
Tin Hut's Avatar
free gasket samples
This link shows different gasket shapes/profiles with an 877 number to order free samples to make sure it's what you're looking for. Prices are good as well per foot. Look at the pic, then scroll down to the bottom for the legend and per foot material.
http://www.jcwhitney.com/webapp/wcs/...&storeId=10101
Old 09-13-2004, 09:15 AM   #5
The Sh*tt*r's Full!
dbtolman's Avatar
1970 27' Overlander
lewisville , Texas
Where can window gaskets be had locally?
I don't want to order my gaskets and then wait... I also can't determine the original shape of the gaskets since they are all dry-rotted and beyond recognition... I want to replace all of them at once...
Now that I know what adhesive to use, can anyone tell me where I might have luck picking up some decent (but not expensive) gasket material that will work for the windows on my 70 Overlander?
(I'm local to DFW area, in case you know somewhere around my parts.)
Thanks in advance!!
dbtolman is offline   Reply With Quote
Old 09-13-2004, 09:58 AM   #6
Tin Hut's Avatar
I'd try Home Depot, Lowes, Auto Zone, etc.
Old 09-13-2004, 11:58 AM   #7
The Sh*tt*r's Full!
dbtolman's Avatar
1970 27' Overlander
lewisville , Texas
Given the deteriorated state of mine, does someone have a PIC of what the proper gasket should look like? ;-)
Old 09-13-2004, 12:13 PM   #8
Tin Hut's Avatar
I'll see if I still have a piece from the '67. I had half moon shaped style that the po put on and it sealed well. The windows he didn't get to I ordered some and what I got was a u shape (flat on the bottom). The site I posted several replies back has pics and dimensions of many styles. The link below is a good source for many things Airstream. As long as it fits the window edge and seals tight & is durable it'll do.
http://airstreamdreams.com/
Old 09-13-2004, 12:34 PM   #9
dbtolman
The correct window and entrance door gasket for your 1970, "is not" available from anyone, except Airstream.
Our part number for that gasket is 45295.
Old 09-13-2004, 02:47 PM   #10
Creampuff
Creampuff's Avatar
1957 22' Flying Cloud
1971 31' Sovereign
2014 25' Flying Cloud
Malibu , California
Images: 60
The "Tire" is not likely to have it. (I'm an expatrioted Canuk).!
Try a bodyshop supplier in Peterborough or failing that most appliance parts houses carry it for dryer drum gaskets.
Murray
AIR #189
"If aluminum isn't magnetic- why am I so attracted to to it?"
Creampuff is offline   Reply With Quote
Old 09-13-2004, 09:40 PM   #11
The Sh*tt*r's Full!
dbtolman's Avatar
1970 27' Overlander
lewisville , Texas
dbtolman
Thanks, Andy. I saw the picture of the gasket on your site. Looks like a hard one to find anywhere. How many feet would you estimate is needed for a 70 Overlander 27' w/o the Vistaviews? I'd like to do the door too. I'm guessing (don't have the coach readily available to go measure) 100 ft would do it? If so, you quote .80/ft on your site. What's shipping for 100 foot of this?
Thanks!
Daniel
Old 09-14-2004, 12:47 AM   #12
JohnG's Avatar
I got to do the gasket thing to on my 75 Sovereign. I plan on doing them all right away. Guess I will buy the material before the sale ends at Inland RV even though I won't get to it for a month or so.
Just adding my 2 worth
John G
___________________________
1975 31ft Sovereign International
........Rear Bath Double Bed Model
Tow Vehicle:1999 GMC Serria SLE Classic 1500 5.7Ltr
System: Jordon 2020 Ultima Brake Controller
Hook-Up: Equalizing Hitch and Sway Bar
JohnG is offline   Reply With Quote
Old 09-14-2004, 12:09 PM   #13
Bob Thompson's Avatar
Corpus Christi , Texas
Images: 67
Another source for weatherstrip is McMaster-Carr at: http://www.mcmaster.com/
Under "FIND" enter: weatherstrip
Then choose: Bulb Seal Weatherstripping
Once you see a catalog page number, enter page: 3212
Then go to item: 21
The 5/8" wide by 3/8" high "D" shape bulb is the just slightly larger than the OEM. The OEM measures about 9/16" wide by about 3/8" high. The price is not too bad also. Plus, it comes with adhesive backing.
Enjoy!
Bob Thompson is offline   Reply With Quote
Old 09-15-2004, 11:39 AM   #14
JohnG's Avatar
Then go to item: 21
Enjoy!
Don't know if they have the weatherstrip that matches AS but they do have a nice collection and great prices. Thanks
John G
make your own vent pipe gaskets 0557 Roof Vents, Skylights & Fans 13 09-13-2004 11:42 PM
roof vent gaskets Neenm Roof Vents, Skylights & Fans 9 09-06-2004 02:54 PM
New gaskets for Atwood 6 gal water heater j54mark Water Heaters, Filters & Pumps 0 01-03-2004 12:46 PM
Replacing window gaskets for late 60's rluhr Leaks - Weatherstrips, Gaskets, Caulks & Sealants 12 10-23-2003 11:26 AM
door gaskets in 1974 Chas Doors & Locks 14 04-19-2003 09:11 PM
