Old 02-07-2009, 05:04 PM   #29
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
Flat Window
Here's the flat window. Holding up to the door there is about a 1/4" gap at the top and bottom of the curve of the door. Think it will work?
Lumatic is online now   Reply With Quote
Old 02-07-2009, 05:31 PM   #30
Zeppelinium's Avatar
1975 31' Sovereign
1977 23' Safari
Palmer Lake , Colorado
I think I'd use the curved version. You'd have a gap at the center of the ends, but I think it would be a little smaller, about 3/16". With the gap at the ends, you'd have less to fill in, just a small crescent under the ends of the frame.
Zep
Old 02-16-2009, 01:25 PM   #31
Lumatic's Avatar
1993 34' Excella
Images: 16
I found one of those narrower full height curved windows (see Zeps post #26 above) I didn't know I had. It looks like in the door there is a horizontal rib about half way between the level of the lock and the top of the door, right where the window would go. What I wonder is, if adding the window would weaken, strengthen or make any difference to the integrity of the door. What do you think?
Old 02-16-2009, 02:20 PM   #32
If a horizontal stringer in the door must be cut to install a window, simply make sure that the stringer is also attached to the window frame.
That will not reduced the strength in that door area, in any way.
Add an Exterior Door Light? biggoofball Lights - Interior & Exterior 12 09-07-2010 05:13 AM
Rear Door - Window Value willyd 1993-1997 Limited 0 10-17-2008 04:42 PM
Add a storage compartment door to 1976 A/S adonh Exterior Storage Compartments & Access Doors 0 02-21-2008 10:27 AM
door window airstreamers Windows, Doors, Locks & Vents 15 03-06-2007 06:55 AM
Window and Door Weatherstripping skippervido Windows & Screens 1 04-15-2002 03:43 AM
