Originally Posted by Joebanjo
... Why then, is everyone wanting to jump back into the double pane window configuration when Airstream themselves have abandon the notion of double pane windows for their trailers? They must have found the whole concept too troublesome to continue. Can a double pane window really provide that added energy bonus to an all aluminum trailer?...
A year ago I had the
Sovereign up in Seattle for their unprecedented cold December. Average temperature was about 20 degrees for three weeks. If you've seen my thread on the
Sovereign, you'll recall that it has a catalytic heater. All but one of windows were double pane.
The one single pane window collected all the moisture as a thick layer of ice. The double pane windows remained free of condensation. I was very surprised at the stark difference in performance.
It's easy to add BTUs to warm up. It's much harder to subtract them. I'm more interested in comfortable sleeping in hot deserts (Burning Man, etc.). I don't think the double pane window performance is as helpful in hot weather, since a lot of my desert time is boondocking, so the windows are open. But anything that will allow a 13.5K BTU air conditioner to keep up when I've got a hookup in Vegas is OK with me.
Yes, they are a lot of work, but when you break your first inner glass, let me know how much work it is to clean out the shards and then devise some way to properly restrain the outer glass in the thick frame. I'm betting it's almost as much work, maybe more. I'm just saying that converting to single pane may not be "easy." I did it for the one window that I broke accidentally and it was a PITA.
Zep
there is also a guy who single paned all of his windows....
Rebuilding your double pane windows with new "U" gasket
I rebuilt all my double panes windows to new single pane configuration and used new "U" gasket material available from
C.R. Laurence CRL Glazing Vinyl; 1/2" Channel Depth 9/64" to 11/64" Metal Opening - 100 ft Roll | GC725C
Mike
I just copy and pasted that from a thread I was following
http://www.airforums.com/forums/f454...m-37422-9.html
We are about to do most of the stack, vista and wing windows in our 76
sovereign. Just buying material now. Pretty daunting and intimidating. But it's gotta get done so here we go :-O
