Old 01-30-2011, 10:22 AM   #1
Breadbug's Avatar
1969 31' Sovereign
1975 25' Tradewind
Walnut Creek , California
'75 Trade Wind Vista repair.
I've got the interior skin removed and have found all the leak origins. Now it's time to plan my repair. One of my vista windows was repaired by PO and now leaks. The other is blistered. I have read about removing the Lexan with a dremel on the previously repaired window. I am gonna remove the window completely and try to rebuild it. I notice that the frame is welded.
Anybody out there have any help rebuilding the vista window? I'm gonna go with single pane after removal.
Breadbug is offline   Reply With Quote
Old 01-30-2011, 10:34 AM   #2
DanielB's Avatar
1974 31' Excella 500
Charleston , South Carolina
What size is it. Outside frame to outside frame?
As I grow older, I pay less attention to what men say. I just watch what they do.
- Andrew Carnegie
DanielB is offline   Reply With Quote
Old 01-30-2011, 10:39 AM   #3
Breadbug's Avatar
1969 31' Sovereign
1975 25' Tradewind
P.S. One of the windows has the aluminum ring ( the one with plastic inner pane) and the other is original two panes of glass with rubber seal.
Old 01-30-2011, 10:41 AM   #4
Breadbug's Avatar
1969 31' Sovereign
1975 25' Tradewind
I haven't measured them. I assume all the 75 Trade Winds have the same size vista windows. Anybody know the dimensions?
Old 01-30-2011, 10:46 AM   #5
silverleeper's Avatar
1967 22' Safari
1960 Caravel
Edmonds , Washington
Images: 8
Found this thread on a quick search. http://www.airforums.com/forums/f454...des-73519.html.
There are more threads on this. Google Custom Search
Lee
1973 F-250 4X4 390
1965 Chevy Suburban 454
AIR 6030
WBCCI 4258
TCT
silverleeper is offline   Reply With Quote
Old 01-30-2011, 10:51 AM   #6
Breadbug's Avatar
1969 31' Sovereign
1975 25' Tradewind
Thanks. I read that thread and was hoping someone had photos of their work in progress. I love these forums because I can almost always find how-to's with pics.
Old 01-30-2011, 12:34 PM   #7
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
Which type of Vista do you have? The one with the glass inner or the plexi inner? They are made totally different. Also be very careful, broken Vista Views are EXPENSIVE.
AFAIK they came in two sizes the more common one is the 32.5", there is also a smaller one, but I have no clue as to the size.
Aaron
WBCCI #XXXX AIR #2495
Old 01-30-2011, 05:01 PM   #8
Breadbug's Avatar
1969 31' Sovereign
1975 25' Tradewind
Aaron
I have both. On the street side is the original plexiglas interior. And on the curb side is a double glass replaced window. Both are small vistas.
ID:	120951   Click image for larger version
ID:	120953   Click image for larger version
Old 01-30-2011, 05:11 PM   #9
x
XXXX , XXXX
Breadbug it is possible to rebuild the windows with the removable trim ring and the inner pane of plexiglass. Here`s how I did mine.
http://www.airforums.com/forums/f454...tml#post864410
wasagachris is offline   Reply With Quote
