Old 10-26-2012, 10:47 AM   #1
1975 31' Sovereign
Tupelo , Mississippi
The outer pane of the front center window on my'75 international sovereign is shattered, apparently from a lawn mower thrown rock. Planning to replace with Lexan. Does any body know the size and thickness of the outer pane?
Ill get a pic posted tomorrow
Nolehoe is offline   Reply With Quote
Old 10-30-2012, 08:56 AM   #2
1975 31' Sovereign
Old 10-30-2012, 02:35 PM   #3
Belegedhel's Avatar
1973 21' Globetrotter
Houston , Texas
I rebuilt the front center window on my '73 (which I expect is the same), and used 1/8" polycarbonate. I don't have the exact height and width, but if you remove the old piece, you can get a good measurement off of that, assuming it stays in one pice. If not, then you can at least measure inside-to-inside of the frame. If you have a table saw handy, you can just buy a 48" x 24" sheet (which should be over-sized), and then cut it down to fit. Lexan cuts real easily with a finish blade.
Old 10-30-2012, 08:52 PM   #4
1975 31' Sovereign
that's pretty much my plan but can't find it locally and wanted to know what size to order. Been trying to find the specs on the original glass but haven't had much luck.
sovereign
Had a nice window rock guard made reasonable Hummer Rock Guards, Segment & Window Protectors 12 08-24-2011 12:09 PM
Cost of Replacing Front Window Screen Fly at Night Windows & Screens 9 08-17-2011 10:45 AM
Window and Door Gasket Kit? 1976 Sovereign gronlampa Leaks - Weatherstrips, Gaskets, Caulks & Sealants 4 08-17-2011 06:22 AM
1975 Sovereign right front window Jim in Pima Windows, Doors, Locks & Vents 3 04-24-2011 07:51 PM
