Old 02-22-2012, 07:56 AM   #1
1972 31' Sovereign
rodanthe , North Carolina
'73 Sovereign windows don't lift open, pull close
Some of my windows won't lift open from the inside and some won't pull closed. Metal fatigue in lifting arms? I'm having trouble homing in on just what is/should be occurring... Would rather not keep buying parts in a process of elimination. Thanks!
fridder13 is offline   Reply With Quote
Old 02-22-2012, 03:00 PM   #2
1981 31' Excella II
Orlando , Florida
If your windows are like mine the aluminum arms can get bent preventing the window from closing. What happens is the rivet that connects the arms hits on the window frame when you try to close it. If they won't open chances are the gasket is stuck to the frame. You did release the locks I hope? Mine you have to pull inward and down to get them to open.
Perry
perryg114 is online now   Reply With Quote
Old 02-22-2012, 05:00 PM   #3
Minno's Avatar
1972 31' Sovereign
Lexington , Minnesota
I have trouble with our 72 Sovereign's windows. They sometimes take strength I don't have to open. They can be adjusted some, but I sometimes end up outside pulling them open. Silicone the gaskets, and that will help keep them from sticking. Adjusting them can help them close better also. Chris can get them open better than I can. I'm hoping the bowflex can help...
Kay
Minno is online now   Reply With Quote
Old 02-22-2012, 06:19 PM   #4
Minno's Avatar
1972 31' Sovereign
another thing that can keep them from closing all the way is the hinge at the top of the arms might need to be cleaned, lubed, and adjusted a bit. I found that when I reinstalled the windows, if I over tightened the nuts, the windows would not drop fully closed on their own. After loosening them just a bit and a shot of silicon spray, they closed much easier. But they can still be a bear to open.
Chris
Old 02-24-2012, 06:29 AM   #5
1972 31' Sovereign
Aha...thank you all. I've got one more closing now and have a better idea of at what/where to look for source of trouble. Part of it might be the needed bowflex too!
Old 02-24-2012, 06:43 AM   #6
moderator
Ottawa , Ontario
Here's the video from the "Classic Rides" DIY Restoration series that deals with windows. Some very good info.
Looking to sell your Airstream or buy a different one?
Or maybe you need a part or just want to sell one?
Be sure to look in at http://www.airstreamclassifieds.com
Aage is online now   Reply With Quote
Old 02-24-2012, 08:49 AM   #7
tphan's Avatar
Longmont , Colorado
The largest windows are the toughest to do from inside, from a combination of weight, poor leverage, and sticky weatherstripping. If they seem particularly resistant to opening, I'll just make sure they are unlatched and go outside, get a finger(nail) under the bott6om edge, and pull them open. You can then put the arms into whatever position slot you want, from the outside.
tphan is offline   Reply With Quote
How to reseal windows 92landyacht Land Yacht/Legacy Motorhomes 8 04-03-2012 06:16 AM
Sneakinup will do great things with this Sovereign TomW 1977 Sovereign 28 03-03-2012 06:36 PM
'73 Sovereign windows don't lift open, pull close fridder13 Windows & Screens 6 02-24-2012 08:49 AM
1977 Airstream Arogsy Motorhome Vintage Ready to Drive anywhere Nice clean open eBay Watch Airstreams on eBay 0 02-22-2012 06:50 PM
1973 Sovereign 31' luxxCon Trailer Values 9 02-21-2012 07:39 PM
