Old 02-03-2014, 01:06 PM   #1
1972 25' Tradewind
fort lauderdale , Florida
'72 rear window questions
I've started removing my windows to clean them up, replace gaskets, guide tracks, etc..
1. My dual pane rear window is plexi (and/or lexan). i researched the forum and to my understanding, this is NOT original? Is that correct? Should I replace both panes with glass? convert to a single pane window?
2. The black, dirt looking substance in between the panes,(see pic) Is that some kind of foam that has deteriorated? What was its purpose?
3.What type and size rivets are being used to fasten the tabs for raising and lowering the window, as well as the joint connection of the frame itself? (see attached pics)
4. I had one of the window latches shear off on me and the other is in bad shape. I assume a few of the others will not be restorable as well. Besides inlandrv, does anyone know of a less expansive source to purchase these latches?
thank you
ID:	204861   Click image for larger version
ID:	204863   Click image for larger version
ehodg66 is offline   Reply With Quote
Old 02-03-2014, 01:16 PM   #2
garry's Avatar
1969 31' Sovereign
Broken Arrow , Oklahoma
It is repairable and others will let you know how they did it I used Lexan on the single pane but;
It may be time to look for a replacement I think they are safety glass and to get a good seal will be hard to do.
I have found Colaws as a good source but there are many others.
RV Salvage Sources
Garry
Old 02-05-2014, 09:07 AM   #3
1972 25' Tradewind
Thanks Garry
Do you know anything about the rivet size?type? and wear to buy/
thanks
Old 02-05-2014, 10:17 AM   #4
mariusg78's Avatar
1977 31' Sovereign
Black Diamond , Washington
Images: 21
I thought the rear window was meant to be an emergency exit, thus the plexi/lexan. That way, if there was a fire in the middle of the AS, you could easily pop the window out and escape.
mariusg78 is offline   Reply With Quote
Old 02-05-2014, 10:23 AM   #5
The rear window can easily be quickly opened for an escape.
To use LEXAN, defeats that purpose, since you cannot break that tough plastic.
Old 02-05-2014, 12:06 PM   #6
Aerowood's Avatar
1971 21' Globetrotter
Arvada , Colorado
Originally Posted by ehodg66 View Post
Thanks Garry
thanks
I've had the same problem with the brackets that attach to the hold open rods and the plates at the bottom where the window lock latches onto.
I used MS20470AD4-4 solid rivets. I countersunk the back side of the brackets so the bucktails would form into the countersinks and then sanded them flush. As I have been replacing the seals I just change out the rivets on the 4 brackets and also on the hinge. Changing the hinge rivets out so the bucktails are flush allows the seal to set flat and also prevents the window from stressing the hinge when closed.
Old 02-05-2014, 12:31 PM   #7
1972 25' Tradewind
Thanks everyone for your input!
Aerowood, you have any pics of your windows after rivet replacement?
thanks
Old 02-05-2014, 01:02 PM   #8
Aerowood's Avatar
Arvada , Colorado
I'm not sure if I took any or not, I'll take a look when I get home. You could look in my thread below, it would be there if I took any pictures.
Old 06-18-2014, 11:11 AM   #9
1972 25' Tradewind
Window rivets
Thanks Aerowood,
I want to use busk rivets to reconnect the window sash, hinge plate, and latch plate rivets. They have a smaller head than shell rivets. Can anyone tell me the exact rivet to use and where to purchase? Part number and/or web link would be a great help
thank you
ID:	214452   Click image for larger version
Old 06-18-2014, 06:07 PM   #10
Aerowood's Avatar
Arvada , Colorado
MS20470AD4-4 but it could be a -3, I can't remember. You can order rivets in 1/4 pound increments here, or just google aircraft rivets. I just mail you some but I am currently out of the country.
http://www.gen-aircraft-hardware.com/store.asp
Old 06-19-2014, 02:21 PM   #11
1972 25' Tradewind
I think you're right with the -4. I checked aircraftspruce.com and AN470AD-4-* is 1/8" dia., where the -3's are 3/32". The holes in the frame are 1/8".
Needing 2 different lengths, One length for the plate attachments and one for reconnecting the frame. Is buying (1) batch of longer rivets and cutting them down for the plate attachments my best option?
thanks
Old 06-19-2014, 05:09 PM   #12
Aerowood's Avatar
Arvada , Colorado
Cutting rivets is a PIA and the bucktail of a cut AD rivet will not form nicely
Old 06-19-2014, 05:30 PM   #13
1972 25' Tradewind
Ok,
2 different lengths it shall be!
Cheers Kip
Vista View Window Questions CBWELL Windows & Screens 15 07-07-2012 08:36 PM
2007 Classic front center window glass/frame interference dznf0g 2006 - 2010 Classic (all lengths) 0 03-23-2011 09:44 AM
rear window on a '66 caravel cojer Windows & Screens 3 02-05-2011 01:10 AM
Front and Rear Window hinge - 1968 Randy Gates 1965 - 1969 Globetrotter 1 01-15-2011 10:05 PM
