Old 09-10-2013, 06:10 PM   #1
airpatton's Avatar
1973 29' Ambassador
Colonial Heights , Virginia
'72 Int. front left/right curved window repair
Does anyone know the correct process for taking out these double pane windows? I have condensation between the panes and they look like crud.
In-between the panes is what appear to be small white pins.
Thanks for the help!
ID:	195406   Click image for larger version
airpatton is offline   Reply With Quote
Old 09-11-2013, 07:23 AM   #2
Belegedhel's Avatar
1973 21' Globetrotter
Houston , Texas
The little white pins are just spacers that were used in the assembly of the windows since the grey putty stays squishy forever.
Have a look at the following thread--it eventually gets on to rebuilding one of those wing windows.
http://www.airforums.com/forums/f164...ld-105478.html
The windows on the 70's trailers apparently came in two configurations, one kind could be rebuilt without completely removing the window frame from the trailer, the other can't. At a glance your windows look similar to the ones I have, which had to be completely removed from the trailer in order to disassemble them. I took apart both of my windows, rebuilt them as single panes, saved the inner glass on each of them for the next time I have a broken window. It wasn't too bad. The worst part of the job was dealing with the four screws that hold the window frames together--they broke off on the first window, so I had to spend a lot of time digging out the broken screws. My second window used stainless screws and they came out in one piece.
good luck!
1997 Limited Classic 34' Front Kitchen?? TomR 1993-1997 Limited 20 11-20-2015 07:03 PM
'58 Hehr Window - Is this the correct window operator replacement? mello mike Windows & Screens 22 10-08-2012 08:49 AM
Front curved pexiglass window shield blowoff! chaimemet On The Road... 0 11-20-2011 07:01 PM
Possible to remove front door window film? tmarquis Windows, Doors, Locks & Vents 9 10-26-2011 09:50 AM
Front plate/tag holder t7389sg Classic Motorhomes 13 06-15-2011 07:24 PM
