Old 06-18-2014, 01:48 PM   #1
1971 31' Sovereign
Lake Minnetonka , Minnesota
'71 Sovereign street side wing window install
I'm having a tough time with this one, here's the situation. I ordered a replacement window. I have 5/32 olympic rivets and grey vulkem for the seal (or should i use 3m Tape). When i place the window into the frame I first tried putting the lock bar on and hammering it into place, but when i do that the window moves too far down in the frame and the existing holes are not even close. Does anyone have any pointers on this? i'm going to guess that riveting the window in place and then trying to put the locking bar on would be a very bad idea. Also whats the best way to get that lock bar to slide down without beating it to death?
bakes is offline   Reply With Quote
Old 06-18-2014, 01:53 PM   #2
1971 31' Sovereign
Also it seems that if the locking bar is on all the way, the corners of the window have a great distance in between the window and the skin, again what would be the best method to close the gap without beating it to death?
existing holes that are large and in rough shape, can i place washers on the back side for the rivets to take better hold?
Last question, the wholes on the new window seem like they are smaller than the 5/32 olympic rivets is that the norm, i take it i'm suppose to drill them out when i'm drilling new rivet holes?
Old 06-18-2014, 02:14 PM   #3
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
Never mind trying to match up the existing rivet holes. I would use the new window frame as a guide and drill new holes. The locking bar is a bugger. Worse comes to worse don't install it. It will be OK.
I did this repair once. Hope never again. Maybe someone else who knows what they are talking about will disagree.
PS Ambient outside temperature may have just enough expansion contraction affect to get the job done, Maybe.
Old 06-18-2014, 05:55 PM   #4
Aerowood's Avatar
1971 21' Globetrotter
Arvada , Colorado
Cleco the window in place and then put some lubricant on the slide mating surfaces and it will ease the installation. Aluminum washers on the shanks of the Olympic rivets is a good idea.
Old 06-19-2014, 09:09 AM   #5
1971 31' Sovereign
So after taking your advise I lubed up the locking bar with WD40 and hammered it into place, the took some rubber strips and hammered the edges down so they were someone flush with the skin, except the bottom lip gap that was kinda large. Drilled my new holes for my rivets, then masking taped around the edges where i didnt want vulkem, pumped vulkem all around the edges. Then I rivetted the four corners of the window. I was very suprised that the gap underneath went away very quick with just the first 4 rivets, and I stopped freaking out. All said and done, what a pain in the butt, but everything looks real nice and my seal seems to be good.
Can anyone tell me why olympic shavers are so crazy expensive!?! I will using a dremel instead of the $235 shaver I cant justify buying right now. Also will i have any repercussions of using WD 40 on aluminum?
Old 06-19-2014, 05:27 PM   #6
Aerowood's Avatar
Arvada , Colorado
I wouldn't worry to much about the WD-40, It may collect dirt as you go down the road so just clean it up with a liberal amount of a degreasing solvent of your choice. You also may want to seal the very top of the slide as water can enter at that point.
Old 06-25-2014, 10:45 AM   #7
1971 31' Sovereign
After further review the olympic shaver is $230, the buck rivet set is like $240 so it makes more sense to buy the buck rivet kit. so I may end up replacing these olympic rivets, not sure yet but here is the before and after, I think i used the wrong Vulkem, is there a difference in the Vulkem and the Tempro Vulkem?
Before
After
Old 06-25-2014, 11:13 AM   #8
1972 25' Tradewind
fort lauderdale , Florida
I apolgize if this is an obvious question but are the replacement wing windows single pain? Glass or Lexan?
ehodg66 is offline   Reply With Quote
Old 06-25-2014, 01:18 PM   #9
1971 31' Sovereign
Single, pretty sure it's tempered glass
http://www.airstreamsupply.com/Wing-...1983-P120.aspx
sovereign
1969 street side curved Wing window for sale? Jake_Seipel Airstream Classifieds 0 05-11-2014 07:06 AM
Curbside Wing window and window by door L&R Rock Guards, Segment & Window Protectors 5 07-07-2009 10:45 PM
Fabrication of Hehr Street Side Window rek Windows & Screens 0 05-04-2007 12:12 PM
Street side window broken on '71 sovereign DaisyandDave Windows & Screens 2 03-28-2006 06:23 PM
