Old 10-07-2007, 08:23 PM   #15
Originally Posted by Don Boyd
here are pictures of my window seals. I dont think i can just cover them over with vulkem. i think i will have to cut some of the seal away in orsed for it to look good.
Attachment 46696
Attachment 46697
Put some Vulkem in the window sash.
Push the gasket in place and hold it there with duct tape.
When that cures out, then install the Vulkem over the entire gasket.
A little trickey, but it will work.
Old 10-10-2007, 10:18 PM   #16
Tallahassee , Florida
Assume it won’t work.
Any other alternatives? Or just vulkum?
catzdragon is offline   Reply With Quote
Old 05-12-2013, 08:46 PM   #17
1971 27' Overlander
Jackson , Tennessee
window gasket still a problem
This old thread addresses a problem I currently have - same gasket problem as shown in the photos above. Has their been any solution to develop over the years? If I have to disassemble the frame, can the rivets be bucked without damaging the glass?
Alan
TennTex is offline   Reply With Quote
Old 05-12-2013, 09:54 PM   #18
Alan
Within reason, you won't break the glass.
Use aircraft type tools for the riveting.
Old 05-12-2013, 10:02 PM   #19
Alan
Alan.
Taking thw window apart won't do much good. The window gasket is not for sale by Airstream.
It's much easier to just cut the gasket away, and then run a bead of smooth Sikaflex where the gasket used to be.
That saves a bunch of time, is easy to do, costs very little, and has no risks.
Old 05-20-2013, 01:00 PM   #20
1971 27' Overlander
Jackson , Tennessee
Thanks, Andy. I'll get started on that repair. Btw, I was surprised by the amount of water that gets trapped inside the frame from that gap in the vinyl gasket.
Alan
