vista view window
Starker, If you are near Bolingbrook, IL stop by the local Airstream dealer. They are Airstream of Chicago (US Adventure RV) at 535-South Frontage Road (just off I-55) on the right before the Bolingbrook Exit Rt. 53, if going north from I-80. Their phone number is 630-972-9700...Ask for Scott Mattera (tell him I referred you...Ralph Carver) I believe you can still get the window complete or just the glass from Airstream. You must however order it thru a dealer. If the Quad Cities is closer for you then you can call the parts manager, Ed in their Davenport, IA store at 563-468-4678. Again tell Ed I referred you. They are great to deal with and will help you however they can to obtain the parts you need. You may be able to get a shop sevice manual by checking the search function here and typing in manuals, service, to see if they are in print for your model year. There is a Secretarial Services that has many older manuals available to purchase. Hope this helps you. Ed
1967 Safari Twin "Landshark" w/International trim package
2014 GMC Sierra 1500 Double Cab SLE
FORUMS MEMBER SINCE 12/16/2004AIR#7110
"My tire was thumping, I thought it was flat. When I looked at the tire, I noticed your CAT!" Burma Shave
