Old 08-06-2015, 09:54 AM   #1
1970 31' Sovereign
Boynton Beach , Florida
70 Sovereign Stack Windows Different Size
On my trailer, the lower left street side oval stack window is smaller than the one to the right. I have only seen replacement windows that are 33 x 10 1/4 inches (frame included), which I assume is the standard size and which is the size of my lower right oval window. The lower left oval measures approximately 32.5 x 9.5 inches, frame included.
Is this typical, or has anyone run into this? I need to replace the lower left window. Any thoughts, ideas, sources?
Thank you!
Panther79 is offline   Reply With Quote
Old 08-06-2015, 10:02 AM   #2
1973 31' Excella 500
Marysville , Washington
Check out Inland RV. If you don't need the frame you may end up replacing the glass with some other material i.e. Lexan. I have Lexan (or Plexiglas?) on one window. It doesn't fog the same and glass and it doesn't bead water the same as glass. Easy to identify its not glass under those conditions. It only bothers me when I have too much time on my hands.
John
Not Done is offline   Reply With Quote
sovereign
Aluminum vent stack caps for 1968 Sovereign cheetah1 Exterior Restoration Forum 13 05-03-2016 10:50 AM
Finally got around to breaking my stack windows Taylormade Windows & Screens 4 08-12-2012 01:35 PM
Rebuilding Wet Oval Stack Windows dbj216 Windows, Doors, Locks & Vents 0 06-18-2012 04:34 AM
Windows, windows, windows... Balquin Windows & Screens 4 07-04-2006 06:35 PM
Different Looks on Different Computers COArgosy78 Forum Admin, News and Member Account Info 3 09-20-2003 02:38 PM
