Old 02-03-2010, 02:11 PM   #1
1969 27' Overlander
Lehi , Utah
'69 window removal/replacement Question
I was going to replace all of the seals in my Overlander with the windows still in place. Then I broke out my front window and had to remove it and that seemed quite easy to remove but the rest of the windows seemed a bit different. do they just use a small c-clip where the bottom posts hook in? And if so are they easy to come by?
Clay C
ClayC is offline   Reply With Quote
Old 02-03-2010, 04:29 PM   #2
Clay C
Those "C" clips are available at most hardware stores or Home Depot.
