Old 06-04-2012, 02:38 PM   #1
1968 24' Tradewind
Cedar Hill , Missouri
'68 Tradewind replacing rear window - HELP?
I was mowing the pasture around my 68 Tradewind and heard a POP. Rock through the rear window of my Tradewind. Does anyone know how to get the top piece off with the hinge? From what I can see I have to take about 12-15 rivets out to get it out. Is that the only way?
bbrowdy is offline   Reply With Quote
Old 06-04-2012, 07:36 PM   #2
kokopat's Avatar
Hendersonville, NC , North Carolina
No, you don't take out any rivets. Go inside, remove the screen, roll what's left out a little bit and across the top you should see 6 phillips head screws. These screws hold on a strip of metal that squeezes the glass to the outer piece (plus some glass bedding and caulking and stuff. InlandRV has the replacement, however if you're going to be mowing a lot I would put lexan back since that is one of the flat glasses.
There's more info on here somewhere - you got to search it out.
Good Luck,
Pat
kokopat is offline   Reply With Quote
Old 06-05-2012, 07:08 AM   #3
1968 24' Tradewind
thanks, now on to Inland RV
Hi, thanks for the quick reply. ordering the glass today.
