Old 11-13-2018, 11:21 AM   #1
1973 Argosy 20
1968 24' Tradewind
Kingsville , Ontario
68 Tradewind - replaced the gaskets and they still leak
I recently began a restoration of a 1968 Tradewind and ordered new gaskets from VTS and have redone all the windows. Unfortunately I now have leaks where I didn't have leaks, I'm wondering if the gaskets are too thick towards the mid/top portion of the window. Any one else have a similar issue, any other pearls of wisdom?
roostream is offline   Reply With Quote
Old 10-23-2019, 05:39 PM   #2
1967 24' Tradewind
Berlin , Berlin
I have the same problem. Did you solve it? Or can anybody els help?
severin is offline   Reply With Quote
Old 10-23-2019, 11:09 PM   #3
Dwwalker18's Avatar
1967 24' Tradewind
North Pole , Alaska
I have a 1967, and have a similar issue. Until I figure out a permanent fix, I’ve had to leave the windows open a crack and place something under the window bars to catch Drips. Definitely interested in recommendations from others!
And sorry I don’t have any help to offer.
Dwwalker18 is offline   Reply With Quote
Old 10-24-2019, 05:37 AM   #4
TomW's Avatar
1967 26' Overlander
Huntsville , Alabama
I replaced all my '67 Overlander's seals in 2004 and everything is still good. You can read about it here:
http://home.hiwaay.net/~tomorkim/WindowSeals.htm
Of note:
* every couple of years the windows are opened so the seals can be sprayed with silicone spray.
* While Inland Andy sold me the double-lip seals, his store now only sells D-seals.
* To seal hinge leaks, Inland Andy recommended pumping RTV into the hinge & operating the window to distribute it.
Hope this helps,
Tom
Frustrated! Replaced antenna to Jack, replaced connections....still nothing. 09 27 jholder Audio, Video & TV 10 06-10-2018 09:05 PM
New axles - they're here, and they will require... drboyd Axles 34 07-17-2016 12:55 PM
Still new, still starting Bullit Member Introductions 25 04-25-2014 06:36 PM
"didn't know they still made those...." FiveGreers On The Road... 13 04-22-2006 10:07 AM
Do they Still Make Airstreams? Steph Our Community 18 08-19-2003 06:21 PM
