There are rubber inset strips on the inside of the window all around it. You will need to carefully remove those. Then you will have to be careful to clean the sealing compound out from around the glass. Then you should be able to remove the glass.
Tedd Ill
AIR#3788 TAC IL-10
No trailers...
I see the rubber seal it looks like it surrounds the glass. do you need to remove the angle bracket at each to remove the broken glass? also I have purchased glass for the front and back window (uncurved) does anyone know the size I need to order for the living room front lower pane driver side. Will 3mm tempered glass fit in this frame?
