Old 09-28-2010, 06:59 PM   #1
1968 26' Overlander
Belwood , Ontario
'68 Overlander Small lower window
How do you remove the lower window pane in a 68 overlander??
Pete66GMC is offline   Reply With Quote
Old 09-28-2010, 07:20 PM   #2
till's Avatar
Lisle , Illinois
Images: 108
There are rubber inset strips on the inside of the window all around it. You will need to carefully remove those. Then you will have to be careful to clean the sealing compound out from around the glass. Then you should be able to remove the glass.
Tedd Ill
AIR#3788 TAC IL-10
1967/8 Overlander International Twin w/ bunk/s.
Yes, four kids and two adults in the thing.
Happy wife, happy life.
till is offline   Reply With Quote
Old 10-12-2010, 04:52 PM   #3
1968 26' Overlander
Belwood , Ontario
I see the rubber seal it looks like it surrounds the glass. do you need to remove the angle bracket at each to remove the broken glass? also I have purchased glass for the front and back window (uncurved) does anyone know the size I need to order for the living room front lower pane driver side. Will 3mm tempered glass fit in this frame?
Old 10-13-2010, 08:59 AM   #4
till's Avatar
Lisle , Illinois
Images: 108
I am not sure about the need to remove the angle brackets. I will measure the thickness of the glass to see. Do you have mid twin beds?
Tedd Ill
AIR#3788 TAC IL-10
