Old 04-07-2004, 01:31 PM   #1
'68 Globetrotter fixed window repair
This is the small bottom window by the door. It is leaking. Anyone have an idea for repair?
JUDITH L. SMITH is offline   Reply With Quote
Old 04-07-2004, 01:44 PM   #2
Vintage Alum. Enthusiast
flyfshr's Avatar
1959 24' Tradewind
Phoenix , Arizona
Images: 40
When you say this window is fixed, do you mean it won't open? Or has it been fixed prior to your proposed fix? Is it the slatted kind?
FF
4CU 2699 / AIR 10 / TAC AZ-1
I'm haunted by aluminum.
flyfshr is offline   Reply With Quote
Old 04-07-2004, 02:02 PM   #3
Sorry to be unclear (this is first posting - new owner). The window is not slatted. It is the small fixed panel non-opening window immediately below the hinged opening window curbside forward of the door. Thanks for your reply.
Old 04-08-2004, 07:26 PM   #4
Judith.
The "fixed" or "stack window" as they are called are easily fixed with Par bond sealer.
DO NOT USE RTV OR SILICONE SEALER.
Silicone sealers will not stay in place very long. Then when you find that the leaks starts all over, you cannot seal the area correctly, because the silicone materials created a barrier, as well as attracts dirt making the seal, dirt colored.
Simply clean the metal and glass junction. Apply Par bond to that metal glass junction.
Using Par bond is as simple as using tooth paste. If you smear it, wipe it off.
If you wipe silicone material off, it eventually will take on the dirt color. Ask Airstream. They learned the hard way.
"Cindy" My 68 Globetrotter - Compounding! Bryanhu Cleaning, Stripping & Polishing 3 04-03-2004 06:23 AM
Window Lifting Arm Repair Davydd Windows & Screens 9 08-22-2003 07:23 PM
1955 Flying Cloud Window and Vent Repair Steph Windows, Doors, Locks & Vents 2 08-05-2003 02:27 PM
Front Wing Window Repair Charles D. Bennett Windows & Screens 0 08-10-2002 06:04 PM
