67 Tradewind window part needed
I been to Inland RV, and Andy didn't have it.
I need two of the cranks that grab the window clip at the bottom of the window and pull it tightly closed. Actually I need two of the threaded brass parts that the crank handle fits onto and one of the spring steel parts that catch the window clip to pull it back.
I could sure use someone's help in finding these.
I've been cleaning all of the window parts. They had 36 years of crud and rust. Some windows were hard to open because the operator was hard to turn even without the window weight on it. We are also having all windows rescreened using original frames, and we will replace all screen clips. I've already fabricated a new rock guard for the front. This should be it for windows, and then off to the next task. I'm sure glad all the Corning glass was intact.
