Old 10-27-2011, 01:15 PM   #1
SilverHoot's Avatar
1967 24' Tradewind
Greenville , South Carolina
'66, '67, '68 Corning Window Clips
See for yourself the difference. One size does not fit all. VTS sells two different clips one for 1/8" thick windows and one for 3/32" thick windows. If your windows are original then they 3/32". The clip on the right is what I bought first from another source and was not a good fit for either window thickness. Very happy with the VTS clips.
ID:	143779   Click image for larger version
SilverHoot is offline   Reply With Quote
Old 10-27-2011, 01:19 PM   #2
clancy_boy's Avatar
2003 22' International CCD
Kiln , Mississippi
Images: 8
So true, made the same double purchase from one source - they are not cheap.
Michael & Tina with Layla and Preston BZ
The family has grown.
2003 22' INTERNATIONAL CCD
Old 10-27-2011, 01:54 PM   #3
Squeezing the clip makes it fit just the window glass.
Or, later on, you can add the metal edging if you wish, which makes them universal.
No need for any silicone.
Old 10-27-2011, 02:58 PM   #4
TomW's Avatar
1967 26' Overlander
Huntsville , Alabama
We Belong to a Mu-tu-al... Ad-mir-a-tion Society
... Very happy with the VTS clips.
I was too. Details are at this link.
Tom
Old 10-27-2011, 04:37 PM   #5
BIGED52's Avatar
1967 22' Safari
MILAN , Illinois
Same here!
I too bought the larger clips. At the time they were all that was available. They do work if you squeeze them together, but it was just not the fit and finish I was looking for. So when VTS started to make them... as others have done I bit the bullet and purchased an entire new batch to FIT all my windows. I am very happy with them. Thanks VTS! Ed
1967 Safari Twin "Landshark" w/International trim package
1999 GMC Sierra 1500 SLT
FORUMS MEMBER SINCE 12/16/2004AIR#7110
"My tire was thumping, I thought it was flat. When I looked at the tire, I noticed your CAT!" Burma Shave
BIGED52 is offline   Reply With Quote
Old 10-28-2011, 07:46 AM   #6
silverleeper's Avatar
1967 22' Safari
1960 Caravel
Edmonds , Washington
Images: 8
Thanks for posting this information. I too have gone through this.
The first set of clips (not from VTS) were to weak and even with silicone to glue them to the windows I still had problems with the clips.
The second set of clips (from VTS) have been no problem and I did not need silicone. The clips from VTS are much thicker.
Lee
1973 F-250 4X4 390
1965 Chevy Suburban 454
AIR 6030
WBCCI 4258
TCT
silverleeper is offline   Reply With Quote
Old 10-28-2011, 08:40 AM   #7
kevinb's Avatar
1968 24' Tradewind
1959 17' Pacer
holly springs , Georgia
another interesting fact; the 1/8" clips vts sells will fit perfectly over original 3/32" glass with ss trim worked great on my 68.
Kevin
kevinb is offline   Reply With Quote
