11-25-2010, 09:34 AM
Baltimore
, Maryland
'64 jalousie HELP!!!!!
Okay, asking for help, and even have a photo...
I need help finding a pair of these carries. They are off a 1964 Sovereign
11-25-2010, 09:41 AM
1963 22' Safari
2020 27' Globetrotter
State of
Happy Thanksgiving Frank, can you give me a rivet to rivet measurement on those rusty steel rivets and the width between the tab retainers for the glass?
Scott & Megan
VAC LIBRARIAN WBCCI 8671
1963 Safari from the 1963-64 Around the World Caravan
11-25-2010, 04:25 PM
Baltimore
, Maryland
Attachment 115929
That is 4 1/8" from front to back.
1 1/4" between the rivet holes.
1 3/4" from the top hole to the rear of the carrier.
apparently a very important measurement is from the front inside edge to the lower hole which is 2 1/2"
I know they are out there. I need a right and two lefts. One pair will get me by, but would like to replace the other if possible.
11-25-2010, 04:33 PM
2006 22' International CCD
1957 26' Overlander
Plymouth
I am very interested in these parts as well. I have a pair of jalousie windows from a 1964 Airstream. I am looking for 1 set, right/left
Any info would be very appreciated
11-25-2010, 06:36 PM
1963 22' Safari
State of
Frank I sent you an email from my phone with a picture, think there are two there that would work, not three though. Will keep my eye out for more, they are the same as 63 BTW. Brad if I come across more I'll let you know.
Scott & Megan
11-25-2010, 09:47 PM
1975 Argosy 26
1963 24' Tradewind
Seattle
Gee Frank, I was going to suggest VTS, but then I noted that they said it was NLA.. then checked online with Hehr, and it seems that all the supply places are selling a 2 1/8" one. Too bad it has so many cut outs and bends, it looks like it might be easy to make without those spring bends.
I'm stumped too!
Marc
11-26-2010, 11:43 AM
1964 30' Sovereign
1959 22' Flying Cloud
1957 26' Overlander
Raglan
, New Zealand
the long way around
Hi, I purchased a modest number of pairs of brackets for jalousie windows some time ago from VTS. I have not ended up using them and would have to check their dimensions, but you are welcome to acquire them if they are any use to you......oh, and I should qualify that by saying have to find where they are hiding in my workshop first!
Pete
11-26-2010, 04:59 PM
1960 33' Custom
Athens
, Georgia
Hey Frank, with the correct material these were actually pretty straightforward to make for my '61. If you get stuck drop me a note.
William
11-26-2010, 06:06 PM
Baltimore
, Maryland
I have been told a pair are on the way...
11-27-2010, 08:18 AM
1997 34' Limited
1963 22' Safari
Troy
, Michigan
Paul
Troy, MI
1963 22'Safari
1997 34' Classic FK
