Old 10-02-2006, 01:38 AM   #1
a.k.a. Ambassador Tim
Safari Tim's Avatar
1960 28' Ambassador
Northern , California
Images: 35
'60s Window questions
I'm trying to get my trailer sealed up before the rains come.
These windows look a little questionable to me. The first photo is an overview. The second one is a close up of the corner. All my windows look this way. There is a hard plastic peice that doesn't quite make it all the way around. And what appears to be some kind of dried up material in the corner.
What is the proper way to fix this? Also, what is window glazing?
Thanks in advance!
ID:	26515   Click image for larger version
-Tim
theVAP - Airstream Podcast
Old 10-02-2006, 06:18 AM   #2
tbrom's Avatar
1965 28' Ambassador
NewCastle , Pennsylvania
Tim,
My 65 has the strips butting up to make a mitered corners all around.
Tbrom
tbrom is offline   Reply With Quote
Old 10-02-2006, 06:54 AM   #3
Got gandkids?
Jim & Susan's Avatar
'Possum Holler , Georgia
Tim, maybe I can help a little. IIRC, window glazing refers to the window glass. Glazing compound refers to the putty-like material that holds the glass in the frame. Somebody will correct me if I'm wrong.
That plastic stuff on the outside, is it decorative or does it appear to actually hold the glass snug against the frame? I seem to remember years ago that you could buy it at the hardware store. Maybe try a window/glass repair shop?
www.nesa.org
Air No. 6427
Old 10-02-2006, 07:49 AM   #4
Sugarfoot's Avatar
1958 22' Flying Cloud
1956 30' Sovereign of the Road
1963 16' Bambi
Southeastern Area , Tennessee
I've got the same issue
AKA Ambassador Tim, my Ohio '60 Tradewind has the same problem. I don't believe the windows have ever been touched, removed, reglazed, or regasketed. However, I've never had any leaks and there is no evidence of past leaks. But it looks shoddy. Was this a way for the factory to cut corners? If anyone knows why our windows are like this, or has appropriate solution, I would also be interested.
Name:	Window Gaskets.jpg
Traveling With Elvis
life with a 1956 Sovereign of the Road
Sugarfoot is offline   Reply With Quote
Old 10-02-2006, 09:09 AM   #5
1963 19' Globetrotter
Moline , Illinois
Think you need this.
Your windows look like the ones on my '63 Globetrotter which had the same glazing strip. You can get what you need to replace this from Vintage Trailer Supply. I believe you need the Hehr Hall-Mark 12 glazing strip. The glass is set into the frame in a bedding tape that they also sell.
It is a fairly easy job to replace this glazing strip. Just pull out the old stuff, clean the channel it was in and install the new using a thin flexible putty knife to get the new strip in. I mitered the corners and sealed the joint with silicone(Red Devil has a grey silicone caulk the matches the color).
Don't mess with the glass unless you have to.
63air is offline   Reply With Quote
Old 10-02-2006, 09:11 AM   #6
rschulz's Avatar
, Utah
Hi Tim,
Just recently discovered The VAP. Finished #20 this morning and I've listen too the 3 most recent ones too. Great Podcast!
I have a '59 Tradewind with the same problem. There are original gaskets that have shrunk over the past 40+ years. They do need to be replaced because they are hard and dried out, can leakespecially if it happens along the top edge, and just plain look bad. On mine, my father in law (the PO) put chaulking on the bare spots to keep them from leaking. I'm hoping to replace them once spring comes.
Rod
'59 Tradewind 24'
(looking for a tow vehicle to replace the bicycle )
rschulz is offline   Reply With Quote
Old 10-02-2006, 09:12 AM   #7
Mel
Mel's Avatar
1967 22' Safari
1960 Caravel
Edmonds , Washington
The windows on our '60 Caravel look the same. I would imagine that when new, the glazing strip fit but shrunk over time. A PO kindly filled the gaps on our windows with lots and lots of silicone caulk. I have all the supplies to fix the windows, courtesy of Vintage Trailer Supply. Just haven't been motivated to get to work on it yet!
Mel
Mel is offline   Reply With Quote
Old 10-02-2006, 10:50 AM   #8
Safari Tim's Avatar
1960 28' Ambassador
Images: 35
Great info guys.
I kind of thought it should go all the way to a mitered corner.
So the glazing tape, holds the window in and the glazining bead, which is the part I pictured, helps shed water and gives it a finished look.
After looking at Vintage Trailer Supply, I see they have a bead for '58 - '60 and a different one for '61 on. So they say its best to check yours first.
While I have your attention, I going to replace the weather gasket on the window frame at the same time. It looks like the best way is to remove the window. To do that, do you simply remove the 4 screws on the opening operators and lift the window up until it drops out of the hinge?
Thanks for the info everyone!
-Tim
Old 10-02-2006, 01:46 PM   #9
MarkR's Avatar
1951 21' Flying Cloud
1960 24' Tradewind
Folsom , California
Images: 12
there's usually (on mine anyway) a very small "set screw" at the middle/top of the hinge, keeps the window from sliding side to side. When I replaced my gaskets I removed the screw and slid the window out sideways . . . I didn't even try to raise the window high enough so that it would "drop out" of the hinge. Hope it works that way, otherwise you'll have to remove the screw.
Good Luck, MarkR
Aluminumbskull with Led Balloon in Drag
Birch Plywood and Aluminum go together like
Peanut Butter and Chocolate
MarkR is offline   Reply With Quote
Old 10-02-2006, 01:51 PM   #10
Safari Tim's Avatar
1960 28' Ambassador
Images: 35
Mark,
Can it slide out with the rain gutter in place?
-Tim
Old 10-02-2006, 03:28 PM   #11
rschulz's Avatar
, Utah
Hi Tim,
I had a couple of my windows out a few days ago. (My windows just missed the dip rail as I as sliding them around. I was replacing the screws that hold the window crank in. I am slowly replacing all the old rusting screws which stainless steel. The ones I used on the window cranks are allen heads and they sure look good, a more finished look then a phillips head.
P.S. If ayone has a lead on a 1959 window crank I have a broken one that would be nice to fixed before the snow flies.
Rod
'59 Tradewind 24'
Old 10-02-2006, 03:39 PM   #12
Images: 59
Originally Posted by rschulz
. . . I'm hoping to replace them once spring comes.
Right. I bought the glazing bead and the bedding tape two years ago, and still have it coiled up in the garage.
The corners on my '59 have shrunk at least an inch in each corner. And the original bead is as stiff as a popsickle stick. The new stuff is very flexible, feels like silicone rubber.
I get around to it someday. None of my windows leak around the glass, so it's probably one of those things that can wait till I hit the road.
Installed my air conditioner today!
Old 10-02-2006, 03:48 PM   #13
Safari Tim's Avatar
1960 28' Ambassador
Images: 35
Don,
Tell me about your air install? What unit did you go with? If a roof mount, did you have to re-enforce ther roof, or did you already have an original A/C and just replaced it?
-Tim
Old 10-02-2006, 05:44 PM   #14
Images: 59
Tim,
I have a Penguin 13,500, with the CCC and heat strip. There was no A/C previously.
I framed the opening while I had all the interior skins out last year, and put in the drain tube and 120Vac/12Vdc/thermostat wiring. I placed the opening about 6" behind the front 14x14 vent opening.
The framing I used was 1 1/2" aluminum channel, and 1/8" aluminum shim to match the curvature of the roof.
I needed to modify the gasket on the bottom of the AC to clear the condensate drainage channels.
If you plan to go the Penguin with drain tube route, let me know, there are some other mods you shoudl know about that aren't worth talking about here.
Here are some pictures of the opening and finished install.
ID:	26544   Click image for larger version
ID:	26546   Click image for larger version
Old 10-02-2006, 05:54 PM   #15
Safari Tim's Avatar
1960 28' Ambassador
Images: 35
As usual, very nice work Don!
I'll PM you with additiional questions.
-Tim
Old 10-02-2006, 07:30 PM   #16
BIGED52's Avatar
1967 22' Safari
MILAN , Illinois
Removing 66', 67', And 68' Windows
Tim, If you look on the VintageTrailerSupply Website under windows, then under replacement windows for these three years, Steve H. has kindly made available the instructions on how to remove the old glass and reinstall new glass for all three type windows hinge configurations. You can just print them out! Yours will most likely be the type #3 window clamps and hinges which are the most owner friendly type of the three. Those are the same ones on my trailer and on Ingrids' tailer (Pinkflamingoes). There are two or three threads under the Windows, Skylights, and Vents section here on the forums that she and I have been sharing our experiences on replacing these windows. I hope this is the information you need and good luck! Ed
1967 Safari Twin "Landshark" w/International trim package
1999 GMC Sierra 1500 SLT
FORUMS MEMBER SINCE 12/16/2004AIR#7110
"My tire was thumping, I thought it was flat. When I looked at the tire, I noticed your CAT!" Burma Shave
BIGED52 is offline   Reply With Quote
Old 10-02-2006, 08:57 PM   #17
Shacksman's Avatar
1960 28' Ambassador
1998 25' Safari
Avonton , Ontario
Originally Posted by Safari Tim
Mark,
Tim, there is a screw at the ends of the rain gutter. Remove one and the end of the gutter will bend up slightly and allow the window to slide out. They don't lift up and come off the track.
The glass is held in with the glazing tape which seals against water, the grey bead is more for looks.
I found the tape at a window repair shop. I had 3 broken windows to figure this out.
Doug & Terry
VAC - TAC ON-1
60 Ambassador Int.
1950 Spartan
1966 Globetrotter
Shacksman is offline   Reply With Quote
Old 10-02-2006, 09:42 PM   #18
Sugarfoot's Avatar
1963 16' Bambi
I appreciate all the info here, thanks everyone. Interesting, never realized it could be a shrinkage problem. Now I have one more thing on my list to order from VTS. Oh man, will my list never end?
Old 10-02-2006, 10:03 PM   #19
Safari Tim's Avatar
1960 28' Ambassador
Images: 35
Interesting Doug,
I wondered why the ends had screws instead of rivets!
Good info everyone, thanks!
-Tim
Old 10-02-2006, 11:42 PM   #20
Shacksman's Avatar
1960 28' Ambassador
1998 25' Safari
Avonton , Ontario
Interesting Doug,
Tim I replaced the rusty screws with olympic rivets, shaved them and they looked great. Then when I went to remove the windows I had to drill out the rivets . You can save that step!
Doug & Terry
VAC - TAC ON-1
60 Ambassador Int.
1950 Spartan
1966 Globetrotter
