Old 03-10-2011, 08:36 PM   #1
mello mike's Avatar
1958 26' Overlander
Mesa , Arizona
Images: 53
'58 Hehr Window - Is this the correct window operator replacement?
One of my Hehr Windows has the wrong window operator and only opens about 4 inches. Here's a pic of a correct operator. The closest match I could find for a replacement was this window operator from VTS:
Window Operator - Gear 7-11/16"
This one from VTS looks like it will fit, but the arm is straight while the ones in my Overlander are slightly curved. I want to be certain before I order it. Can anybody confirm for me?
1958 Overlander
2011 Wolf Creek 850N TC
2011 Ford F-250 Crewcab (6.2L), 3.73RE
WBCCI #5661/AIR #5661/TAC # AZ-6
4CU 1st VP
My '58 Overlander Restoration and Travel Blog:
http://mellomikesairstreams.blogspot.com/
mello mike is offline   Reply With Quote
Old 03-10-2011, 08:38 PM   #2
DanielB's Avatar
1974 31' Excella 500
Charleston , South Carolina
If it fits you might need two to make both sides the same.
As I grow older, I pay less attention to what men say. I just watch what they do.
- Andrew Carnegie
DanielB is offline   Reply With Quote
Old 03-10-2011, 09:31 PM   #3
Vintage Trailer Supply
VintageRV's Avatar
1956 22' Caravanner
Montpelier , Vermont
7-11/16 Operator for Hehr Standard Windows
Hi Mike, it fits. The old operators are no longer available. The version that is available should fit your same mounting hole spacing and has an arm slightly shorter than the original, but it operates the same way. The modern version has stamped gears so it doesn't strip out the way the old ones did, but they are not quite as beefy in dimensions. They're the only version that fits that are still made. Don't forget you'll need the little nylon pad that fits in the end of the arm and rides in that front channel.
Steve Hingtgen
WBCCI #1573
VintageRV is offline   Reply With Quote
Old 03-10-2011, 10:06 PM   #4
ddstech's Avatar
1958 22' Flying Cloud
Folsom , California
I'm glad to hear this, I was not clear on which ones were correct.
ddstech is offline   Reply With Quote
Old 03-11-2011, 05:35 AM   #5
mello mike's Avatar
1958 26' Overlander
Mesa , Arizona
Images: 53
Awesome! Thanks Steve.
1958 Overlander
4CU 1st VP
Old 03-11-2011, 08:09 AM   #6
Silverfoxrae's Avatar
1957 26' Overlander
Saint Augustine , Florida
Images: 45
Oh, good to know. I think I'm missing one. Haven't found the parts yet in the trailer, so I will be ordering at least one. Maybe I should get a few in case the old ones start wearing out...
Rae
via~ AIR Forums App.
Metallicised.
AIR # 42703
TCT Member
TAC # FL~6
WBCCI # 1464
'57 Overlander thread:"the end of the rainbow is silver"
Silverfoxrae is offline   Reply With Quote
Old 03-24-2011, 09:59 PM   #7
mello mike's Avatar
1958 26' Overlander
Mesa , Arizona
Images: 53
Well, I ordered the 7 11/16" window operator from VTS, but the base holes don't line up with the old operator. The VTS operator base is approximately 3 1/4" long while the old operators on my Overlander were 5 1/2" long. This appears to be the only operator available.
Will the backframe grommet from VTS allow me to mount the 7 11/16" operator to my window?
1958 Overlander
4CU 1st VP
Old 03-24-2011, 10:31 PM   #8
pbearsailor's Avatar
Port Hadlock , Washington
I've had the same issue in mine, Mike, and I've just used one of the holes and fastened the other through the slot. Still works fine. I've not used the backframe grommet on any of those in my trailer.
-steve
Forum Thread: First She Had to Take a Ride on a Boat
Blog: My 57 Caravanner
pbearsailor is offline   Reply With Quote
Old 03-25-2011, 10:53 AM   #9
mello mike's Avatar
1958 26' Overlander
Mesa , Arizona
Images: 53
-steve
Steve,
Sorry for being thick headed, did you use a sheet metal screw with a washer and nut when fastening through the slot? It seems like the slot is too big to screw into.
1958 Overlander
4CU 1st VP
Old 03-25-2011, 11:32 AM   #10
Don't think that's being thick-headed, Mike.
Been awhile on mine, but I'm pretty sure I had to just slightly open up the steel channel in the frame with a drill. Wanna say I used 8-32's or something similar for the screws. You can't add much depth inside the steel channel of the frame or the closer arm won't have enough room and the window won't close completely. This seems like a bigger problem on my smaller windows.
Anyway, what worked the best on mine was the screw head and a thin flat washer inside the channel and the nut on the interior side of the window.
To me, Steve's closers don't look as good as the originals, don't function quite as smoothly, but, like he says, have a better and stronger gear setup in side and should last well. Those original gears strip out easily and I'll wind up replacing all 9 of mine.
Old 03-25-2011, 12:30 PM   #11
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
The gear mechanism in mine lasted about twice. I did not like those replacements and am looking for something else.
Old 03-25-2011, 07:23 PM   #12
ddstech's Avatar
Folsom , California
Really?? The replacements from vts? I just ordered some.. Great.
Old 03-25-2011, 08:14 PM   #13
reinergirl's Avatar
Hollis , New Hampshire
Funny I was just reading an article today about a home remedy for fixing a stripped window crank and was wondering if it might work?
Read about it about halfway down the page in the link below. Look for the photo titled "Fix a stripped crank handle" and read the paragraph below
How to Repair Old Windows | The Family Handyman
reinergirl is offline   Reply With Quote
Old 03-25-2011, 08:31 PM   #14
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
Thanks for that.....it is the teeth on the mechanism of mine that turned to mush.
AS280 - Front (driver) sliding window latch dalefox Classic Motorhomes 14 09-13-2018 08:05 PM
Hehr window glass replacement for '58. mello mike Windows & Screens 4 02-25-2011 08:36 AM
Got my window out. Now what? Breadbug Windows & Screens 3 01-23-2011 07:27 PM
1950 Flying Cloud Needs Window Replacement happy123 Windows, Doors, Locks & Vents 2 01-10-2011 05:56 PM
