Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Windows, Doors, Locks & Vents > Windows & Screens
Old 08-28-2009, 11:38 AM   #1
Profile:  1954 22' Flying Cloud
San Francisco , California
50's Hehr Windows
I'm seeking advice on where to look for 50's Hehr windows. I need to replace two damaged window sash's in my 1954 Flying Cloud. The sash sizes are 23.5"x13.5" and 23.5"x8"(one of two in the window). Any advice will be greatly appreciated. Thanks, scott42
scott42 is offline   Reply With Quote
Old 08-28-2009, 11:45 AM   #2
wkerfoot's Avatar
Profile:  1979 23' Safari
1954 29' Liner
Orange , California
Scott,
They come available on Ebay from time to time. Also join some vintage trailer groups on Yahoo and place a request. You could also try Tin Can Tourists. They were used on many different trailers in the 1950's.
Bill
Just my personal opinion
1973 Dodge W200 PowerWagon, 1977 Lincoln Continental
wkerfoot is online now   Reply With Quote
Old 08-28-2009, 07:51 PM   #3
Originally Posted by wkerfoot View Post
Scott,
Bill
Thanks! I'll check your suggestions out.
scott
Old 09-29-2009, 08:42 AM   #4
Addicted to Aluminum
A-Merry-Can's Avatar
Profile:  1959 18' "Footer"
1964 24' Tradewind
1954 29' Liner
Woodstock , Georgia
Did you ever find your hehr window? I'm in need of the same size for my Liner (23.5"x13.5"). Mine works, but has some unsightly holes in it. :-S
If you run across 2, I'll buy one from ya!
JP
8576 • • • • • • • •
there's always room for one more!
• • www.toolbox-design.com • •
A-Merry-Can is offline   Reply With Quote
Old 08-28-2009, 12:17 PM   #5
Commercial Vendor
soldiermedic's Avatar
Profile:  1975 29' Ambassador
1953 21' Flying Cloud
O'fallon , Missouri
Send a message via Yahoo to soldiermedic
This is the inherant problem with these windows other than the PITA you deal with while restoring them...they are hard to find, and if you happen to find one, bid high and often because there are others in the same boat as you.
Good Luck!
Steve
soldiermedic is offline   Reply With Quote
Old 09-29-2009, 10:54 AM   #6
Profile:  1963 24' Tradewind
Cape Coral , Florida
Can you TIG weld the holes and then grind and polish smooth?
dieseleagle is offline   Reply With Quote
Old 09-29-2009, 08:24 PM   #7
1964 24' Tradewind
1954 29' Liner
Woodstock , Georgia
not metal that thin. Plus it's a little bent up. I'd rather try to find another one, if i can... especially since i have the time.
Old 09-30-2009, 11:26 AM   #8
I did not find any windows with the dimensions I needed. I had wrinkled up the lower front corner pretty bad and couldn't find a replacement so my approach was t get any window and cut up and splice which I'm sure will work. Before I started to cut I started to straighten the corner and it responded without coming apart so with some judicious hammering I was able to put it back into usable condition.
So I have a window complete with frame and operator with a frame dimension of 40"x17 3/4" that is for sale.
Anybody interested?
Cheers,
scott
Upgrade Windows vs Hehr Windows??? TomR Windows & Screens 5 08-19-2009 06:08 PM
Hehr vs. Full tilt windows. Soyboy Windows, Doors, Locks & Vents 26 09-30-2008 03:18 PM
Replacement Hehr windows wander'n Windows & Screens 13 04-03-2008 10:12 PM
1963 Hehr Windows uwe Windows & Screens 11 06-11-2006 09:39 AM
50's Table?? GT1963 Cabinets, Counter Tops & Furnishings 17 09-03-2004 04:01 PM
