08-28-2009, 10:38 AM
1954 22' Flying Cloud
San Francisco
'50s Hehr Windows
I'm seeking advice on where to look for 50's Hehr windows. I need to replace two damaged window sash's in my 1954 Flying Cloud. The sash sizes are 23.5"x13.5" and 23.5"x8"(one of two in the window). Any advice will be greatly appreciated. Thanks, scott42
08-28-2009, 10:45 AM
1979 23' Safari
1954 29' Liner
Orange
Scott,
They come available on Ebay from time to time. Also join some vintage trailer groups on Yahoo and place a request. You could also try Tin Can Tourists. They were used on many different trailers in the 1950's.
Bill
Just my personal opinion
https://billbethsblog.blogspot.com/
08-28-2009, 11:17 AM
Florissant
, USA
This is the inherant problem with these windows other than the PITA you deal with while restoring them...they are hard to find, and if you happen to find one, bid high and often because there are others in the same boat as you.
Good Luck!
Steve
08-28-2009, 06:51 PM
San Francisco
Originally Posted by wkerfoot
Scott,
Bill
Thanks! I'll check your suggestions out.
scott
09-29-2009, 07:42 AM
Addicted to Aluminum
1959 18' "Footer"
1964 24' Tradewind
1954 29' Liner
Woodstock
, Georgia
Did you ever find your hehr window? I'm in need of the same size for my Liner (23.5"x13.5"). Mine works, but has some unsightly holes in it. :-S
If you run across 2, I'll buy one from ya!
JP
there's always room for one more!
09-29-2009, 09:54 AM
1966 26' Overlander
1963 24' Tradewind
1990 34' Limited
Cape Coral
Can you TIG weld the holes and then grind and polish smooth?
09-29-2009, 07:24 PM
1959 18' "Footer"
1964 24' Tradewind
1954 29' Liner
Woodstock
, Georgia
not metal that thin. Plus it's a little bent up. I'd rather try to find another one, if i can... especially since i have the time.
09-30-2009, 10:26 AM
San Francisco
I did not find any windows with the dimensions I needed. I had wrinkled up the lower front corner pretty bad and couldn't find a replacement so my approach was t get any window and cut up and splice which I'm sure will work. Before I started to cut I started to straighten the corner and it responded without coming apart so with some judicious hammering I was able to put it back into usable condition.
So I have a window complete with frame and operator with a frame dimension of 40"x17 3/4" that is for sale.
Anybody interested?
Cheers,
scott
01-27-2010, 01:03 PM
1959 18' "Footer"
1964 24' Tradewind
1954 29' Liner
Woodstock
, Georgia
Anybody interested?
Cheers,
scott
Do you still have the window? If so, can you post a pic or 2? I might be interested in it if I can come up with a plan to fit it in. :-)
01-28-2010, 04:56 AM
1956 22' Caravanner
Sarasota
Hehr Window
Anybody interested?
Cheers,
scott
Good work. We are restoring a '56 Caravanner and have been searching for this size window! If you are still interested in selling, please let me know.
Lynne & Ed eeb1147@verizon.net lynnezee2@verizon.net
01-28-2010, 05:11 AM
Baltimore
, Maryland
I am not going to break any rules by soliciting, but you folks looking for those Herh standard windows might want to PM me or contact me via email. I just might know where you can find them
01-28-2010, 01:19 PM
1959 18' "Footer"
1964 24' Tradewind
1954 29' Liner
Woodstock
, Georgia
I'll pass. I was going to make a spot for it, or cut it down... seems criminal if someone has an exact fit for it!
JP
01-28-2010, 01:37 PM
San Francisco
Hi, I still have the window.The frame dimensions are 39 3/4"x17 5/8". Will fit in an opening40"x18". The window is in good shape. The operator and sash lock both work. The gasket is hard and should be replaced (Vintage Trailer Supply has the gasket), the screen has a 1/8" hole, The vertical struts in the frame are rusty and can be cleaned, treated and cold galvanized easily, there is no glass in it (I recommend putting tempered single strength in it-the stops are all there. VTS has the small machine screws and stamped nuts to replace the originals. All in all it is very worthy to be fixed up and put in your trailer.
I paid $200+shipping and would expect the buyer to pay the same.
See photos.
Cheers,
scott
01-29-2010, 05:41 AM
1956 22' Caravanner
Sarasota
Window
Great...we'll take it. Please call me at (941)223 9546 so we can
make arrangements or email me your # and I'll call you.
eeb1147@verizon.net.
Thanks, Ed
02-15-2010, 05:35 AM
1993 21' Sovereign
birmingham
, la
Another Hehr Standard Window Donor needed -
Guys,
I could do with a hehr window also, for my little 55 Whale Tail Ohio bubble -
34 7/8 wide x 14 tall.
Infact, I could do with various window bits from a 54/55 if there is anyone out there that can help please PM me.
Sam.
02-16-2010, 06:55 AM
1993 21' Sovereign
birmingham
, la
Attached is picture of trailer and the window needed
Trailer is located in Europe for the second time in it's history. On the left is my wife aluminitus, her green house and on the right my aluminitus that needs the window.
03-18-2010, 07:13 AM
1953 21' Flying Cloud
McKinney
Several 50s Hehr Standard currently available on E-bay. I just bought one. I've been looking for two years for my 53 FC.
03-18-2010, 08:01 AM
Florissant
, USA
They are a rare find, and that's for sure. Kudos to you for your find!
05-16-2010, 05:23 PM
1953 17' Clipper
Montevallo
, Alabama
I have a question about the window screens in my '53 Clipper. Most of them are actually in OK shape but some have rips. How do I replace them? It looks like the center post with the opening levers is riveted and the screen goes between the metal strips on the inside and outside. I can't see how to fix this. I've got some galvanized steel insect screen from Vintage Trailer Supply on the way but now I am afraid it is all for nothing. Thanks for any guidance.
