Old 04-13-2005, 07:02 PM   #1
25' Safari Window
Just had something or someone break a window. Best options for replacing?
daleunc1 is offline   Reply With Quote
Old 04-14-2005, 06:21 AM   #2
Aluminum Condo III
kamadeca's Avatar
2015 30' International
Saskatoon , Saskatchewan
Broken Window
We had our window broken as well. Tried a local glass place, but because the window has two different radii (top to bottom, and side to side) they couldn't do anything for us. Ended up having to order a whole new window (frame and all) from Airstream. My dealer took the glass out of the replacement frame and installed it on the trailer. If anyone needs a frame for the curbside rear window of a 2003 25' Safari SS (sans window) I have one!
Malcolm & Randy
WBCCI # 12523
kamadeca is offline   Reply With Quote
Old 04-14-2005, 07:13 AM   #3
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Rivet
You COULD put a piece of Lexan in the frame, carrefully wrap it in, say, an old bedspread, and store it for if/when another window gets broken. If you get the Lexan that is "scratchproof" on both sides it should last virtually forever, and you will be able to get up and running in very short order. Also, the Lexan will flex, so it should fit in the frame with no problem.
Window latch dilemma maxandgeorgia Windows & Screens 5 05-18-2018 10:35 AM
Safari VS. Classic Questions kkrogh Our Community 24 12-20-2005 11:10 AM
1974 Excella front window docu post john hd 1973-1974 Excella 500 22 08-06-2004 01:53 PM
Front Wing Window Repair Charles D. Bennett Windows & Screens 0 08-10-2002 06:04 PM
Window Frame Removal 64GT Windows & Screens 4 04-09-2002 12:40 PM
